Old 05-31-2021, 10:16 AM
TAKerry TAKerry is offline
Might experiment with a propane torch, would not trust myself with the Oxy/Ac. As a welder for years ... shrinking hot metal was always the enemy. Spent a lot of time trying to prevent it, or compensate for it ... rarely USE it ... except flame bending long pieces edgewise. Heat with a welding torch in a series of triangle shapes with the base of the triangle on the side you want the inside radius to be ... but that was always metal at least 1/4" thick.
Sorry for the hijack, but there was an old timer welder pop would use. This guys first career was as a fabricator at Beth Steel in Bmore. He told me of a time they were shaping large I beams for bridge work. Said there were a gang of guys with rose bud torches heating the beam to bend it.
To get back to the original program, I had to repair some accident damage on the lower back quarter of a car, I did use a contour gauge comparing to the other side. But like Musclah said, as long as its close, youre only going to see one side at time.
Old 05-31-2021, 11:02 AM
MUSLCAH MUSLCAH is offline
A set of torches with the small brazing tip...is the ticket for shrinking metal. A small fine ..pointy flame. The propane flame is way too big ..IMHO.
The Following User Says Thank You to MUSLCAH For This Useful Post:
Old 05-31-2021, 06:20 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
I wouldn't use a propane torch, that will only cause more problems as it heats to large of an area and takes to long allowing the heat to disperse on the panel distorting it.
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
The Following User Says Thank You to n20ta2 For This Useful Post:
Old 06-01-2021, 02:47 AM
dataway's Avatar
dataway dataway is offline
You just gave me a reason to buy and new set of torches. I've lost half the tips for mine and it's pretty much obsolete anyway, can't get parts for it.
Old 06-01-2021, 05:59 AM
nytrainer's Avatar
Iíve used my stud welder with the shrink tip on those pesky high spots then check with a body file.
The Following User Says Thank You to nytrainer For This Useful Post:
Old 06-01-2021, 02:18 PM
dataway's Avatar
Curious how the shrink tip works, something like a copper tip that heats up a spot using electrical resistance like a spot welder?
I just ordered a Harris #1 torch tip which hopefully fits my 1980's Craftman torch.
Old 06-01-2021, 02:48 PM
dhutton dhutton is offline
Yes.
Old 06-01-2021, 02:55 PM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default bodywork
you can even use a mig welder. heat it hammer it down preferably with dolly and then cool it down.
The Following User Says Thank You to Tim66 For This Useful Post:
Old 06-01-2021, 07:45 PM
dataway's Avatar
So pull the wire out of a MIG welder, use an old tip as the contact?
I assume I'd have to play with the settings on some scrap so I don't blow holes in things, including the welder.
Old 06-02-2021, 09:41 AM
Default bodywork
just make believe you're welding a hole 1/2 " after you finish cooling down just grind it and cool with air as you grind
Old 06-02-2021, 02:00 PM
dataway's Avatar
Oh, so you mean actually apply metal with the MIG, I thought it was just using the MIG transformer to provide current to heat a spot of metal.
Old 06-02-2021, 03:31 PM
Default bodywork
The wire is the heat .
Old 06-02-2021, 09:37 PM
What a mess.....
Old 06-03-2021, 12:21 AM
dataway's Avatar
I'll give the torch method a try first I think.
So far my experience for small imperfections has been ... less is better. Get it close and stop messing with it until a more experience hand can look at it.
Old 06-03-2021, 10:04 AM
Default bodywork
I think the torch method works best,I just suggested the mig if you're in a pinch.Good luck with you're build.
Old 06-04-2021, 09:33 AM
I thought you meant using an old tip too. Like dataway, I am curious as to how the shrinking tips work and what they work with. Do they make something like that for a standard wirefeed MIG?
Sent from my moto g stylus (2021) using Tapatalk
Old 06-04-2021, 08:05 PM
This carbon stick set up is the balls. Just remove your tip....wind this rig in...shut the wire speed to off....up the heat a touch....ground said panel...touch the rod to the panel and pull the trigger....flame Less heat to a specific area.
The Following 3 Users Say Thank You to MUSLCAH For This Useful Post:
  #38
Old 06-04-2021, 08:16 PM
Attachment 567749
I read somewhere that you cannot use those with an inverter style MIG. Have you tried it?
Don
  #39
Old 06-04-2021, 08:37 PM
Don
My old Solar 165 mig ran it....Itís best to check with your manufacturer to be sure.
  #40
Old 06-04-2021, 11:43 PM
dataway's Avatar
Excellent ... I'll get one of those, I have two transformer based Lincoln MIGs that should do the trick.
I'd guess it wouldn't work well with an inverter MIG, they use a computer to sense what's happening at the tip and adjust on the fly ... not sure it would play nice with something like this.
Thread Tools
Display Modes
