Old 06-17-2024, 10:12 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Default Torque values
Recently bought a 455 with 1st generation Eheads with studs. My plans were to replace the 72cc with 87cc. Plans changed and the buyer wants to keep the 72cc Eheads on the block. I don't recall having the stud nuts torque values, Any help?
Old 06-18-2024, 06:29 AM
steve25 steve25 is offline
If the heads are still on the motor then what does it matter?
If there ARP studs then go on there site and look up a set of studs listed for aftermarket heads.
Did you get the studs from Butler. KRE, Summit or Jeg’s’s then go on there site or call them to get the needed info.
Old 06-18-2024, 11:58 AM
68WarDog's Avatar
Did you get the studs from Butler. KRE, Summit or Jegísís then go on there site or call them to get the needed info.
The engine was purchased with the studs already installed. I removed the heads to install another set. ARP/ Elderbrock sites list 75 ftpd. Attempting to verify since I'm not familiar with stud bolts. Past 30+ years always used head bolts, 95-105 ftpd.
Old 06-18-2024, 12:20 PM
HWYSTR455's Avatar
I just went thru this when I switched to 340cfm E-heads, and the ARP studs are listed by ARP as 110 ftlbs. (with ARP lube).
https://tech.arp-bolts.com/instructions/190-4305.pdf
That's for the 2002-up series heads, the earlier ones had a couple bolts that were a 'medium' length.
Here's the page that lists all the E-head bolts offered:
https://arp-bolts.com/kits/make.php?...EngModelID=298
The bolts (not studs) are listed as 100ftlbs.
Old 06-18-2024, 12:28 PM
68WarDog's Avatar
Thumbs up
[QUOTE=HWYSTR455;6510037]I just went thru this when I switched to 340cfm E-heads, and the ARP studs are listed by ARP as 110 ftlbs.
Got it. Thanks for the information. For 30 years of running first and second generation Eheads, this is my first with studs.
Old 06-18-2024, 12:38 PM
HWYSTR455's Avatar
Just a suggestion, what I do is install 2 studs and then slide the heads on, then screw in the rest of the studs.
It's easier to get the gasket and head down to the deck that way.
Thread Tools
Display Modes
