#41
Old 11-05-2024, 03:47 AM
...This to combat porn spammers. Sorry for the inconvenience.
ahh
No wonder the naked pics of Rosanne Barr on a Bandit TA never post when I upload them.
She autographed them , just wanted to share.
  #42
Old 11-23-2024, 09:38 PM
Had some time with The Bird today. I thought I'd post up some more pics to let u guys analyze. Is there a stamping on this alternator to verify if it's original? Same questions for the carb & A/C compressor. Sticker on the A/C compressor looks newer, so IDK about it.Click image for larger version
ID:	643379Click image for larger version
ID:	643380Click image for larger version
Sent from my SM-S901U using Tapatalk
  #43
Old 11-23-2024, 09:40 PM
Here's the carb. It's a quadrajet.Click image for larger version
ID:	643382Click image for larger version
ID:	643383Click image for larger version
Attachment 643385Attachment 643386Attachment 643387
  #44
Old 11-23-2024, 10:12 PM
The alternator looks correct.
The numbers should be on top straight out from the 2 wire connector on top.
On the front half.
Alt. #'s
The carb will have stamped numbers on the throttle side of the rear part of the carb. Up & down.
Carb #'s
  #45
Old 11-23-2024, 10:35 PM
This one is not correct for your car - but shows where the stamping is.
Yours should be 7040264
  #46
Old 11-23-2024, 10:41 PM
Alternator codes
Might need to smear some black grease/grime over it to highlight the stamping impressions.
  #47
Old 11-23-2024, 10:53 PM
Ramairnacho Ramairnacho is offline
Default alternator
this is my restored 1100903 if that help you. I got cores too. It's dated in Nov of 69 I think. My car assembled in 1st week of March. It will work.
ID:	643388   Click image for larger version
ID:	643389   Click image for larger version
  #48
Old 11-23-2024, 11:38 PM
M would be December.
They skip "I" on stamped dates of peripherals .
  #49
Old 11-24-2024, 12:22 PM
Even better then it's within range. Thanks .
  #50
Old 11-24-2024, 10:54 PM
Thanks Guys!! The alternator checks out. It's number is
1100 903 55A
Date code is 9M11
The carb is
4988S
Then a C 4 0
I didnt have as good of luck with the carb numbers though. It would only let me search the first 250 of 2062, then it would kick me out. And if I entered the number on the specific search, it would say no results found
The Following User Says Thank You to F Body Freak For This Useful Post:
  #51
Old 11-24-2024, 10:56 PM
Mine has that SE stamp like yours?
  #52
Old 11-25-2024, 07:20 AM
I have a 4987S in database, shows as a 1970 replacement Qjet.
I'd say yours is the same with a newer number? (4988S)
Jon probably would know about it. (if he sees this)
  #53
Old 11-25-2024, 07:44 AM
Carter replacement carb.
Will have Carter cast onto the side instead of Rochester.
As Johnta1 mentioned , CarbKing can probably decipher that application. (PY member)
  #54
Old 11-25-2024, 07:48 AM
Held for Ransom's Avatar
Here is a link to carbking's Carter service replacement list...
https://forums.maxperformanceinc.com...d.php?t=803526
So long, farewell.
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post:
  #55
Old 11-25-2024, 04:52 PM
Good find on that listing Ransom.
And thanks to Jon CarbKing for sharing it back when.
  #56
Old 11-25-2024, 05:29 PM
Was that "common practice" to replace the quadrajets back then? I know my dad had a 69 Impala with a quadrajet on it & he stil curses it to this day, lol It has a C 4 Date code on it. Maybe a C 1. It was hard to read the number.
  #57
Old 11-25-2024, 06:13 PM
It could happen to any car.
But it didn't happen to all of them , just some of them.
Yours is a stock style replacement , it could be worse.
But it isn't factory.
Carter did make some Qjets for PMD assembly line use.
But they had the full application number 7040264 and plant code ,
just a different dating format than the Rochester units.
  #58
Old 11-25-2024, 06:54 PM
A lot of bad gas served from stations during the mid-70's lead to a lot of carburetors being replaced. Date code C4 with a circled "C" sounds very plausible.
So long, farewell.
  #59
Old 11-25-2024, 09:31 PM
It did come from the factory with a Quadrajet, correct? I think at some point, I would like to put a factory correct carb back on it
  #60
Old 11-26-2024, 01:50 AM
unruhjonny's Avatar
Carter manufactured some Quadrajets for Rochester;
Most factory installed Quadrajets were made by Rochester, but some were outsourced to Carter for use on the assembly lines.
As mentioned earlier, they look exactly the same, but have a different stamped application number.
I believe the most common 1970 “Carter” Quadrajet was the 400/auto (7040264).
For all intents that IS a correct carb for your car, it’s just a service replacement that Carter sold through the aftermarket, and not a GM issued unit.
To most, the difference is un-noticeable.
Those carter service replacement carbs can fetch good money - I have some auction listing information saved…
If it functions fine, I’d suggest you leave it in service for now, and move on to other things which might need addressing first.
1970 Formula 400
Thread Tools
Display Modes
