Old 10-22-2022, 03:51 PM
Racer81x's Avatar
Racer81x Racer81x is offline
Default Parting out 1963 Grand Prix
Just drug in a very rusty 63 GP that was used as a parts car for a restoration. Still has some useable pieces.
Car was factory equipped with 8 lugs, factory A/C, power windows, power steering, brakes.
Some of the A/C parts are still there, as well as most, if not all of the power window stuff.
Frame is junk, most of the body is junk.
Roof, firewall, cowl all look straight and solid.
I will cut patch areas from the body if needed.
Located in Iowa, I will ship small items, big items will need to be picked up, or you make shipping arrangements
Let me know what you need.Click image for larger version
Sent from my moto g power using Tapatalk
Old 10-22-2022, 11:03 PM
ed boersma's Avatar
ed boersma ed boersma is offline
Default '63 Gran Prix
I'm looking for a rear tailpipe hanger - it bolts to the top of the rear framerail. Rusty is OK as long as they are solid. $? Thanks!
Old 10-23-2022, 11:37 AM
Keith Seymore's Avatar
Keith Seymore Keith Seymore is online now
I assume it's an automatic?
How are the bumpers? Straight and solid enough for cores?
K
'63 LeMans Convertible
'63 Grand Prix
Old 10-23-2022, 12:24 PM
1964GTOs&TempestWagon 1964GTOs&TempestWagon is offline
Hello,
Does it still have round ball A/C vents for the interior? If so, I would be interested in them if they are not too pitted.
Al
Old 10-23-2022, 04:39 PM
omarsphatt omarsphatt is offline
I'm looking for the A/C duct between the blower case & evaporator case, the passenger kick panel cover, the inner heater box and duct & flange from the inner heater box to the kick panel please. Also any engine A/C brackets & pulleys if available.
Old 10-24-2022, 07:50 AM
Racer81x's Avatar
I noticed there was one still on the car when I strapped it down on the trailer, I'll check it's condition after work today and let you know.
Old 10-24-2022, 07:53 AM
Racer81x's Avatar
K
Automatic car, bumpers were missing from the car, but I do have a couple 63 fronts in storage that would be decent for a daily driver or good core for rechrome. $150 each on those, will have to check and see if I have a rear core.
Bumpers I prefer not to ship
Old 10-24-2022, 07:54 AM
Racer81x's Avatar
Originally Posted by 1964GTOs&TempestWagon View Post
Hello,
Al
They were already missing from this car, but I might have some in storage I'll have to look
Old 10-24-2022, 07:56 AM
Racer81x's Avatar
Some of those parts are still there, some are missing, but I'll check my storage and see what all I can gather up.
Old 10-29-2022, 08:38 PM
gtoguys gtoguys is offline
Does the GP still have the expansion valve for the A/C? It's mounted on the firewall under the evaporator case.
Old 11-01-2022, 09:57 PM
Racer81x's Avatar
These are the only A/C parts I have from the car
Old 11-01-2022, 09:58 PM
Racer81x's Avatar
This the valve that you are referring to?
Old 11-02-2022, 08:14 PM
I'm definitely interested in the parts circled in red, and if gtoguys doesn't grab the valves circled in yellow I'll take those too. Any chance of getting a pic of the other side of that inner heater box?
Old 11-05-2022, 11:20 AM
The small yellow circle is what I need. Mine got plugged when I did the compressor exchange. How much do you want for it?
Old 11-07-2022, 09:54 PM
Racer81x's Avatar
Unfortunately the inner heater box has rot on the inside edge, it will be going in the scarp pile.
$35 for the kickpanel
The cowl kickpanel metal piece is pretty rotten, as is the seal, I'll just give those to you if you want. I can send you pics of them up close first.
The valves I'm just going to sell them all complete with the whole plastic housing for $50
Old 11-07-2022, 09:55 PM
Racer81x's Avatar
I don't want to split the 2 valves/plumbing and box up. $50 for the whole box with the valves
Old 11-08-2022, 10:29 PM
I don't need all the pieces. Please sell it to omarsphatt. Thank you for waiting on me.
Old 11-10-2022, 06:27 PM
I think I'll have to pass as well, I just found a set of kick panels elsewhere that are the correct color for my interior and I already have a nicely refurbished evaporator case. Thanks anyway.
Old 12-27-2022, 06:48 PM
HOPontiac HOPontiac is offline
Send a message via AIM to HOPontiac
Default 63 GP Parts
Do you have per chance a good RH (Pass) side rocker Molding ?? Also looking for window Frames for both front door glass, and front wheel opening moldings
Thank You
Old 01-15-2023, 11:20 PM
Racer81x's Avatar
Thank You
Sorry don't have any of them
