#41
Blackcat: It looks like you have a bunch of really descriptive picture of your install. Do you mind if I add some of them to Pics Gallery on pypesexhaust.com?
"No you fool, we're following orders. We were told to comb the desert so we're combing it." |
#42
Not at all!
That is why I did the Install! I like to do this in order to help others. Usually I'm found working on my Pontiac. If you want to find me Look for the white picket fence and all the old Pontiacs parked outside. And the half dissembled engine sprawled all over the driveway!
Try calling CRUSHPROOF! 512-386-9889 |
#43
how do you tell if you have the standard or the HO manifolds? Austin is just up the road....come on down and help me put some on !!!!!
1965 GTO Convertible, Blue Mist Slate. 1967 GTO Hard Top Coupe, Champagne Gold 2005 G6 Sedan, Electric Blue |
#44
The car has the Standard Exhaust Manifolds.
The 7K3's are missing the end bolt hole and pad for it. Usually I'm found working on my Pontiac. If you want to find me Look for the white picket fence and all the old Pontiacs parked outside. And the half dissembled engine sprawled all over the driveway!
#45
I thought that some completed pix are in order for the Inquiring minds!
Here is the X-Pipe! Usually I'm found working on my Pontiac. If you want to find me Look for the white picket fence and all the old Pontiacs parked outside. And the half dissembled engine sprawled all over the driveway!
#46
The front View!
#47
Here is the rear view for you all.
#48
Here is the view by the gas tank.
#49
Here is the Axel view.
Sorry, My rear is being converted to disks and Posi. More oomph and stoppage needed for that Ram3 cam! Usually I'm found working on my Pontiac. If you want to find me Look for the white picket fence and all the old Pontiacs parked outside. And the half dissembled engine sprawled all over the driveway!
#50
Passenger's side.
#51
Is that your fuel line under that axel view?
How close is it? Thats a problem I have with my current set up. I reallllllly like those pipes. Did you spot weld the connections? How did you do it?
#52
That's the line. Plenty of room!
More than the stock setup. Usually I'm found working on my Pontiac. If you want to find me Look for the white picket fence and all the old Pontiacs parked outside. And the half dissembled engine sprawled all over the driveway!
#53
Did you weld it after it was up or while on the ground?
NEVERMIND....I see the clamps now [This message was edited by lampoon on October 09, 2003 at 12:25 PM.]
#54
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Ccass:
Many of you have expressed a need to upgrade your exhaust system but didn't want to spend the extra $350 + installation for the RA/HO manifolds or headers. We have just completed these sample downpipes for standard manifold cars. As you can see they include the correct flanges. Notice that the pipe is 2 1/2" but is downsized for a couple of inches to allow for the flange to fit. After the flange is installed, the pipe is flared for attachment to the standard exhaust manifold. <HR></BLOCKQUOTE> So whats your price on this setup and how was the flange different before for regular manifold guys who wanted to go up to 2-1/2"?
#55
It's just like the Pictures.
If you want you can visit and see for yourself. I'm in south Austin Usually I'm found working on my Pontiac. If you want to find me Look for the white picket fence and all the old Pontiacs parked outside. And the half dissembled engine sprawled all over the driveway!
#56
This summer I made a pipe like this the hard way out of pieces. I'll keep in mind next time the car needs head pipes.
It's a '73 big car with its original manifolds. The outlets are 2", there is a 2" long piece of 2.25" with a flare against the manifold, the 2.25" is then welded into the trimmed end of a 90 degree 2.5" elbow. That was alot of work to install, pull clamps down real tight to locate it, uninstall, get the two parts welded together, remove clamps, reinstall on car. BTW, on a big car the pipe can come straight down, bend 90 degree then go straight back past the trans for a while on both sides. It can be gotten to clear everything including the extra braces that some cars have that go from the frame under the engine back to the frame under the front body mounts. Mine has X pipe too. Mike |
#57
Can you post pics from directly underneath each manifold? I need to see how they drop off the motor and travel back towards the tranny.
_____________________________ Foolproof and Sucka free since 1979. |
#58
Joe, you looking for something like this. These are on a '69 Lemans.
1966 GTO 1969 Lemans Convertible- F.A.S.T. legal family cruiser. 12.59 on G70-14 Polyglas tires. 1.78 60' 1969 Bonneville Safari- cross country family cruiser. . 1979 Trans Am 400, 4-speed, 4 wheel disc. View from the drivers seat racing down Atco Raceway- http://www.youtube.com/watch?v=GhYDMdOEC7A Ride along in the other lane-http://www.youtube.com/watch?v=mIzgpLtF_uw |
#59
Isn't that X pipe restrictive like a Y pipe on a single exhaust?
I guess I just don't understand exhaust dynamics. I'd like a long branch 2-1/2"system without the X in 304 Stainless. |
#60
Oh man if I only had waited a couple months!!!! Sucks to be me with a system I am less happy with every time I see it! Oh well, live and learn...
1969 Judge (Liberty Blue / Blue, 4SPD) |
