#201
yep
#203
https://share.icloud.com/photos/0zp0...r_Township,_MI
The above picture shows where I'm at now. The crank gear has multiple dots on it and none of them line up with the dot on the cam gear. |
#204
Question;
Can I get a simple timing set and install it lining up the dots and be good to go? |
#205
How are you verifying TDC of #1? Really need a piston stop to be at absolute TDC. Then if the dots dont line up, remove chain, rotate crank until they do
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg |
#206
Is that at TDC ?
#207
What I usually do when installing a timing set is bring up the dot and see if the valves are closed. With one dot it's easy.
#208
I need to determine what's going on with these multiple dots and keyways.
#209
Just by looking at that..the cam was installed wrong. I would personally degree in the new cam to play it safe. No sense tearing it apart twice just to find the new cam and or timing set is off a bit.I would reuse the current timing chain set since it has adjustment. Spend the money on a degree wheel.
#210
Slip the cover/ balancer back on and line up TDC. ...compression stroke Pop the cap on the dizzy and make sure the rotor is pointed near # 1 on the cap. Not 180 out.
Take care or remove the two sleeves that align the front cover, dont want to have to go fishing in the pan for them.😳... or anything else! (Stuff some rags or duct tape the opening.) |
#211
What I'm seeing is that the timing set is installed so it give 0 advance or retard hence the dot by the crank key. Counting the exposed teeth on the cam gear it looks pretty close to six o'clock. The dot on the crank gear tooth adjacent to the crank key should like up with the dot on the cam gear So.
it looks like the cam is installed 2 teeth advanced!
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ([_|_] ##\|/##[_|_]) |
#212
Each keyway will have a corresponding mark for either straight up 2 or 4 degree advanced or 2 or 4 degree retarded to the left of each slot.
A simple way to tell is bring up your crank dot that is just to the left of your keyway to the top. Take a look where your cam gear dot winds up..I bet it is pretty far off.
#213
Looks to me that the crank gear is installed correctly on the keyway. The red arrow shows 4A, which would be for 4 degrees advanced. Probably on the other side out of view is 4R.
If #1 is truly at TDC in this pic, then is was installed a few teeth off.
#214
I have installed cams and you don't need to degree them. Lots of people do it. |
#215
What I'm going to do now is make sure the valves are closed on # one, that would mean it's on compression stroke an TDC when dot on crank gear is up.
Let me know if this is wrong. It's how I installed the new cam on my 69 428 and it worked excellent. I put the edelbrock performer package on that engine back in 1990 and it was a great engine. |
#216
Yes, and number 6 Exh will be opening also.
#217
The crank needs to be rotated clockwise for TDC if this is the 0 keyway.
#218
Yes, I missed that. So remove chain, rotate crank until dot up, then move cam to align dots, reinstall chain
#219
Now here's the problem I have. There's more than one dot on the crank gear. How do I know which dot? This is a cluster**** having more than one dot.
#220
That's the 0 keyway. Just jump 2 teeth so the dots line up and you'll be golden!
