Old 07-10-2024, 02:59 AM
ponchorob ponchorob is offline
Default Tripower end carb check balls
Do the tripower endcarbs have checkballs in the accellerator pump channel .. on one carb it seems theres a ball but its stuck ..on the others theres no ball…
Old 07-10-2024, 06:18 AM
carbking's Avatar
carbking carbking is offline
Yes.
Jon
Old 07-10-2024, 08:40 AM
Default Checkball
So cleand everything and saw the other end carb has also a stuckin checkball in the pump channel ..so my big question how will the carb react when those Checkball stuck as i understand assume the fuel is pickup through the fuel filter screen to transfer in the pump channel so ill think there will be not enough fuel for accellerator shots?
Old 07-10-2024, 05:33 PM
carbking's Avatar
The balls need to come out, or the accelerator pumps will not function.
Jon
Old 07-11-2024, 01:39 AM
Default Checkball
Jon thanks for your response...but isnt the channel under the checkball not only a additional fuel supply ...? As i see therse big slot in acc pump channel where the pump rides where fuel can come in to give a shot ? i will make a test and fill the bowl an see what happens...
Old 07-11-2024, 01:40 AM
But maybe im wrong
Old 07-11-2024, 10:01 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
I bet the wrong size ball was installed
Old 07-11-2024, 08:31 PM
mike w mike w is offline
Default Checkball stuck
Call me to discuss. Mike Wasson
309-360-6385
Old 07-12-2024, 11:08 AM
Default Checkball
Mike thanks for your response and takin part in this thread...since im from austria ill think a longer phone call could get expensive .... my personal email : ramair@gmx.net
Or we can talk here..
Old 07-12-2024, 11:26 AM
Its 421 wirth ramair 4 cam.....i bought the the car as is .since the tripower was running very rich i removed the carbs...to look and saw a lot of things wrong....to be ready i ordered a lot of tripower parts from tripower.com ; several weeks ago ...a lot of rebuild and tuning parts an idle tube drillkit and also got your dvd....after removing the carbs i saw wrong fuel inlets, jetting was not ideal ,one brass float was leakin..i replaced a lot of parts also modified the power piston spring cuttin four coils...but didnt install the carbs after seeing tge stuck checkballs....one other reason maybe for also running rich throttle blades are to far open the transfer is uncovered 0.075 far away fromm the preferred 0.020..but dont think the cam will idle with under 0.040 uncover transferslot...
Old 07-12-2024, 11:29 AM
Assume that uncovering the transferslot so much the booster start to draw a lit of fuel at idle
Old 07-12-2024, 11:37 AM
A forgot to mention its 64 Tripower jetting 63 center 70 outer carbs ,,fuelinlets 0.86 outercarbs now and 0.101 center
Old 07-12-2024, 11:44 AM
Old 07-12-2024, 11:51 AM
Default Check vall
But before installing the carbs have to solve this stuckin checkball issue....since theres also a big slot in the pump channel where the pump rides assume theres also coming fuel to fill but dont know if the works sufficient...
Default Check ball
Old 07-12-2024, 02:44 PM
Kenth's Avatar
Kenth Kenth is offline
On occasions when I've serviced 2G carburettors where someone previously put in the big steel ball under the acc pump and it's stuck, I've taken a 10-15 cm brake pipe and pushed it against the inlet hole where the acc pump filter sits, filled the pipe with oil and held a screw that just fits inside the pipe and tapped on the screw, which then pushes the oil down into the space under the ball and causes it to come loose. Wear safety glasses during this maneuver and cover the acc pump race with a cloth so you don't have to look for the bullet that flew away.
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 07-12-2024, 04:19 PM
Default Checkball
......thanks for your advice will try what you recommend and hope the hydraulic pressure pops the ball out ...
Old 07-13-2024, 04:54 PM
Dick Boneske's Avatar
As has been stated, someone put the wrong check ball in the accelerator pump well. I have removed dozens of them using a method I posted a few years ago on this forum. Kenth described it, but you will see pictures of the actual removal if you search the forum.
You can email me at bocoogto@gmail.com for detail. Meanwhile, I will try to find the link to the info.
BONESTOCK GOATS
'99 Bonneville SE Sedan
