Old 12-15-2019, 12:32 PM
cdrookie cdrookie is offline
Default Tri Power for sale near me for $350
Just saw this. I don't really need it but if it's worth the price I might pick it up. Thoughts????
Name:	tri power $350.jpg
Old 12-15-2019, 12:48 PM
It’s a ‘64 intake, not as popular or as valuable as ‘65-‘66 intakes, might be worth $150-$250 depending on the buyer.
Front and rear carbs are not Tri-Power carbs, can’t be sure about the center carb but highly likely it isn’t either.
At $350 it isn’t worth picking up if none of the carbs are true Tri-Power pieces, might be worth buying for $150 if you happen to need a ‘64 intake.
Old 12-15-2019, 12:52 PM
Thanks Bart!
Old 12-15-2019, 10:28 PM
Dick Boneske's Avatar
Yes, It looks like possible correct center carb, but air horn web is broken. End carbs are correct bodies, but airhorns are not Tripower. $350 is OK as it is. End carb airhorns are $90 each. Center carb airhorn will be hard to find.
If you're not interested, PM me with seller's name. PA to WI would be expensive shipping, but may be worth it.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 12-16-2019, 12:10 AM
Should’ve waited for the expert to chime in first, much respect and thanks to the guys here that really know what they’re looking at!
Old 12-16-2019, 09:02 AM
carbking's Avatar
carbking carbking is online now
Center looks to be genuine. As Dick mentioned, spider is broken, but can be repaired.
Genuine centers are more difficult than genuine ends.
Jon.
