removing exhaust manifolds in a 65 tempest
Being new to the pontiac building hobby I put a 400 in a 65 tempest. The exhaust manifolds were off the 400 I bought and eventually put in the car. They were on the engine when I installed the engine.
I am wanting to pull the heads off and I can't figure out what tool to use to get to the 9/16 bolts holding the exhaust manifolds off. Any tips? I know another Greg deal. Thanks |
I have removed the Head Pipes on Both exhaust manifolds, removed the motor mount bolt on the drivers side, put a block of wood on the oil pan and raised the driver's side and removed that manifold.
Dropped the engine back down on the drivers side frame mount, reinstalled the bolt, removed the passenger side bolt on the mount and repeated the process. (I also loosened the rear trans mount slightly). I had access to a lift. Some monkeying around but makes the job easier. (Thanks Zollie) RIP (a mechanic at my uncles Pontiac dealership). Tom V.
You can't reach them with a box end wrench? How about disconnecting the exhaust pipe from the exhaust manifold, then removing the head with the exhaust manifold still attached?
That would be my vote.
1965 Pontiac LeMans. M21, 3.73 in a 12 bolt, Kauffman 461. |
pull em with the head .... if you round off a corner on the head your squuuewed .....
use a QUALITY 6 point socket with the face shaved down flat so the socket sits DEEP on the bolt use a 1/2 " drive .... put an extension on your socket and smack the socket over the head of the manifold bolts with a hammer to dislodge any grime and get a nice deeep grip on the bolt head ... SOAK all the bolts multiple times on multiple days ,,,, and collector ones also some of the manifold bolts are exposed on the spark plug side .... soak em |
i use a snapon tool,for the places u cant get a wrench or socket on, it usually works,,its 2 inches long and flat, on one end its a box end 12 point 9/16,other end is a 3/8 square for your extension or ratchet. it would work better if it was 6 point but i havent seen one made that way, if u weld make your own..
CAROLYN JONES(1930-1983 Actress)may she never be forgotten!! |
I don't understand your post, but what I can tell you is that ifthe factory Exh Manifold bolts have never been removed then there are thin steel folded up lock tabs on the head of each bolt and if you don't fold or bend them down off the head of the bolt then the needed 9/16" socket does not fit on .
The Following User Says Thank You to steve25 For This Useful Post: | ||
I assumed that he would see the Lock Tabs on the heads of the Exhaust Fasteners but you never know until it is posted.
That's what I did last winter. The downside is the combined weight of the head and manifold together when you pull them off. But once on the bench, you have unrestricted access to the manifold bolts. Lots of PB Blaster.
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
The passenger side is easier, once you get the bolts out (box end wrench or ratchet with swiveling head) it slips right out. Drivers side is tighter but using the same tools it can be removed after you take off the starter, however the center two bolts must stay with manifold during removal or install. No need to jack up the motor but do it if you want more room to work.
Remove the head with the manifold as a last resort, the 80+ pound weight of the assembly is a back breaker.
Thanks everybody Greg |
