Old 10-18-2010, 09:38 AM
rycher rycher is offline
Default 79 trans am trunk color
Hi, I believe the trunk color in my 79 is original. It appears to be a flat black but when I look online, the colors seem to always have a mixture. I'm going to have to go the cheap route for now and use cans from Eastwood ( do not have a spray gun). The closest thing to me is the black/gray. Would one of the other colors be more accurate?
Thanks for any advice.
Old 10-18-2010, 10:30 AM
bigborehunter bigborehunter is offline
For what its worth, all the low mileage unrestored TAs I've seen from the 1980-81 era had very low gloss black paint under their trunk mats. These were Norwood cars by the way. Why not have a look online at some cars reputedly to be un restored originals?
Old 10-18-2010, 11:08 AM
Thanks, that's a good idea.
Old 10-18-2010, 02:47 PM
mikeb mikeb is offline
I sprayed some eastwood undercoating out of a rattle can in my trunk. It goes on thin, and seems to me to duplicate the original coating perfectly after it dries.
Old 10-22-2010, 01:31 PM
yumpy's Avatar
yumpy yumpy is offline
I did some touch up work in the trunk of my original 79 t/a and used eastwoods under hood semi gloss black - 10% - 20% gloss - p/n 10024z - was happy with it matching the present condition of the trunk. wish i would of thought of the eastwood undercoating as i think it would hold up better to the abuse from golf clubs and car show chairs.
steve
Old 12-07-2010, 08:50 PM
Aus78Formula Aus78Formula is offline
Around 1977-early 78 they changed from the spatter paint to black, probably phased in until it ran out so some may have slipped through.
Old 12-09-2010, 04:37 AM
lester's Avatar
lester lester is offline
the 79 trunk is in black primer, the floor pan got a satin black paint. the inside of the 1/4's and behind the seat/speaker area was left in blk primer. the tail panel on the inside of the trunk is the body color. the trunk mat if you had one , was a dealer install. and would be on the dealer info on the PHS.
when I did mine I used a roll on truck bed liner. it looks really good.
Old 12-09-2010, 05:26 AM
Thanks guys,
I wound up using Eastwood's black/grey spackle with low luster clearcoat. I had a little light surface rust, so I put a good coat of rust encapsulator down first. I did the floor of the trunk, inner quarters, and the "behind the seat" area all the same. I know it's not factory correct but I like the way it turned out. Thanks again for all the advice.
Old 12-10-2010, 07:31 PM
Warren Seale Warren Seale is offline
In 79 the felt trunk mat was standard equipment.
Warren
79 T/A,WS6,403,A3
96 T/A,WS6 (#1344) ,M6
72 442,W30,A3
96 Vette convertible Grand Sport (#713),F45,M6
13 Vette 427 convertible (#1425),Z30/Z25,M6
