Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 11-11-2019, 07:38 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
Default Aluminum pontiac torque plate wanted
Looking for an aluminum torque plate for my 461 build using a 400 block. Would love to buy a good used one. Thanks!
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 11-18-2019, 01:01 PM
n20ta2's Avatar
Probably a stretch I know, how about leads on new ones?
Old 11-18-2019, 04:23 PM
Dragncar Dragncar is offline
I did a search awhile back and there was a company selling them for 369$. Might have to buy one myself.
Old 11-18-2019, 04:42 PM
Mike Davis's Avatar
https://ccaracing.com/aluminum-torque-plates/
This is the company I had looked at. I am in need of one as well. I talked to the owner last week. Maybe if there is enough interest I can see if he will give a group discount.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 11-18-2019, 10:30 PM
Thats the company. I need one for a 4.375 bore. Maybe some of us can buy one and share it. I have no problem with the long timers around here.
Old 11-19-2019, 12:23 AM
t money t money is offline
I don’t know if you read the web pages. They do rent them out.
Old 11-19-2019, 01:28 AM
Wouldn't a set of tubular spacers, say an inch long with 1/2-13 bolts torqued to spec do the same thing a hell of a lot cheaper?
Old 11-19-2019, 10:44 AM
Hillard's Avatar
Hillard Hillard is offline
It would be better than nothing, but not quite as good in my opinion.
Old 11-19-2019, 05:25 PM
No. A proper tq plate bore and hone needs to have a head gasket and the same gasket used in the build. It matters. Different gasket distort different amounts.
And some do no know this but you can not just bore without one .004 under like a chevy then tq plate hone. Pontiac bores distort .006. So you bore would not be "round if done that way. You need to bore .010 under or do both bore and hone with the plate but some shops can not do that.
It simply has to do with a 1/2" bolt close to the cylinder edge @ 90 lbs. Pontiac distort more than most.
Old 11-19-2019, 09:29 PM
mgarblik mgarblik is offline
You could give BHJ a call and talk to Mike. They have made 3 plates for me in iron. They will make you an aluminum one, don't know the price. You will probably want to be sitting down.
Old 11-19-2019, 10:27 PM
Look up the price of a BHJ balancer. Well over 500$
Old 11-19-2019, 11:47 PM
Boogy's Avatar
Boogy Boogy is offline
I would be interested in buying one
Old 11-21-2019, 01:45 PM
n20ta2's Avatar
That's a great price and I'm definitely interested in one. If you can get a group rate I'm in for sure!
Old 11-21-2019, 11:41 PM
JD's Avatar
JD JD is offline
I have been in contact with this company via email this week and I have an order in queue. He said there is a one and a half week lead time for any plate order.
The owner of the company is Cam Amrhein and I have been communicating with him via the email address sales@ccaracing.com.
Jim
71 Firebird, best 1/8th mile time of 5.02 at 142 at altitude in Vegas
