Old 03-16-2025, 08:10 PM
silver69judge silver69judge is offline
Default Doug nash 4+1 race transmission torque rating
Just bought a Doug nash 4+1 race transmission for my 63 tempest gasser build. Will it live behind a 550 pounds of torque. Behind a 455
ID:	649003   Click image for larger version
ID:	649004   Click image for larger version
Old 03-17-2025, 04:09 AM
Dragncar Dragncar is offline
Is it cracked ?
Old 03-17-2025, 05:54 AM
No. They have a split case
Old 03-17-2025, 02:46 PM
gobrdgo gobrdgo is offline
I beat on mine with reckless abandon on street tires so far. Zero issues. 455 estimated 450 hp. Got it cheap enough from B man on the board years ago. I use the long shifter.
Old 03-17-2025, 04:18 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
All depends on the ratios mainly first gear in it. Not sure if my old Richmond catalog has the TQ ratings in it I's look tonight. It does for their ST-10s. Back in the day you could give them the Nash serial number and they could look up what ratios it had. Mine was a "NHRA Stocker" so 4th and 5th were 1:1. I swapped out some gears and now 2.80, 2.22, 1.77, 1.33, 1.0.
Skip Fix
2004 GTO Pulse Red stock motor computer tune 13.43@103.4-sold
Old 03-18-2025, 09:12 AM
mysticmissle's Avatar
i have the richmond version in my 69 behind a healthy 455 and a 342 posi and drag radials. it is fine i think torque rating was in the 700ft lb range but that maybe selective memory
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 03-18-2025, 02:49 PM
Stan Weiss's Avatar
If this is what use have. Fully Rated at 600 ft. lbs. of torque
https://www.richmondgear.com/wp-cont...hmond/RG22.pdf
Stan
Pontiac Pump Gas List
The Following User Says Thank You to Stan Weiss For This Useful Post:
Old 03-18-2025, 08:04 PM
That's it
1964 540 gto
Old 03-18-2025, 08:32 PM
Thank you. Should be ok.
Old 03-26-2025, 11:33 PM
wolf's Avatar
wolf wolf is offline
I broke one with my 300 ft-lb Stocker when I had the clutch set too aggressively on a radial prepped lane, so....
Old 04-09-2025, 01:21 AM
Those have a helluva 1st gear - what axle ratio are you running ?
Very stout transmissions (4+1)
Thread Tools
Display Modes
