Old 03-25-2025, 12:43 AM
J.C.you's Avatar
J.C.you J.C.you is offline
Default Stamped steel factory type rockers ?
Is a oem type new rocker available (no roller tips) in a 1.5 , 1.6 or 1.65?
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 03-25-2025, 02:56 AM
Kenth's Avatar
Kenth Kenth is offline
STD 1.5.
RAIV 1.65.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-25-2025, 07:53 AM
P@blo's Avatar
P@blo P@blo is offline
Melling MRK434 for the 1.5:1 and MRK532 for the RA IV. They will run forever even without any rollers.
The Following 5 Users Say Thank You to P@blo For This Useful Post:
Old 03-25-2025, 09:20 AM
track73 track73 is offline
A few years ago, I got some 1.65's from Rock Auto.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 03-25-2025, 05:40 PM
J.C.you's Avatar
Ok thanks for replies. I thought there mite be a ford steel 1.6 rocker that may fit?
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
Old 03-25-2025, 06:29 PM
Formulas Formulas is offline
I dont know of any current sources, I bought my 1.6 stamps from PAW. out of So.Ca. looong time ago
If your not at the table you're on the menu
Old 03-25-2025, 08:26 PM
JSuchma JSuchma is offline
I'm pretty sure I have a few sets of NOS 1.65 factory rockers left, minus the balls, if you're interested.
Old 03-26-2025, 07:15 AM
Sun Tuned Sun Tuned is offline
You can still get them from Melling.
Bought a full set about 1 month ago from Internal Engine Parts here locally for a 350 HO in a 68 Firebird we have the engine out of at work.
Butler also carries them as well.
Old 03-26-2025, 08:23 AM
P@blo's Avatar
Rockauto carries both the part numbers I listed. Does not take much to figure out who is blocking who lol
I still remember being told using wheel bearing grease on my upper shaft bushing was wrong. Now it's right but 15 years of use proved otherwise long before...
Old 03-26-2025, 08:36 PM
Yeah rock auto , and probably anywhere else that can get Melling parts….theyre still available.
Old 03-26-2025, 10:01 PM
J.C.you's Avatar
Got a set 1.5 set from butler coming. Seems a 1.6 stamped set would be a good seller?
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
Old 03-26-2025, 10:59 PM
I would think 1.6 would put 1.5 out of buisness, ... If they quit making 1.5 at this point in time who woud cry ? ... There isnt much downside to 1.6 not to much of a chance of a crash and pushrod holes dont need to be worked and a bit more lift to be had
Old 03-27-2025, 12:41 AM
unruhjonny's Avatar
unruhjonny unruhjonny is online now
Originally Posted by Formulas View Post
I would think 1.6 would put 1.5 out of buisness, ... If they quit making 1.5 at this point in time who would cry ? ...
The pure stock guys would cry;
They’d all be ineligible to run!
1970 Formula 400
Old 03-27-2025, 08:45 AM
Yeah your right that group has got to be huge...
Old 03-27-2025, 11:01 AM
unruhjonny's Avatar
ha-ha!
1970 Formula 400
Thread Tools
Display Modes
