Old 03-26-2025, 03:23 PM
64speed's Avatar
64speed 64speed is offline
Default Colder plug
I am using the NGK 4554. What is the next down colder plug?
Old 03-26-2025, 03:52 PM
misterp266's Avatar
Here’s an NGK chart. You’ll need the long number. The example is a BP6ES-11. Hope it helps.
" Darksiders Rule "
The Following User Says Thank You to misterp266 For This Useful Post:
Old 03-26-2025, 04:55 PM
steve25 steve25 is online now
How did you determine you need a colder plug?
Old 03-26-2025, 05:28 PM
64speed's Avatar
My buddy that races a 69 Lemans said it was worth a try after looking at mine.
Old 03-26-2025, 06:25 PM
A Worth a try comment to me sounds like your having issues, is that the case?
Keep in mind that just eye balling at a plug from a motor with street miles on it tells nothing unless your at the extreme’s of the plugs heat range in your motor now.
Old 03-26-2025, 07:20 PM
64speed's Avatar
I was trying to determine if it’s detonating. You’re right the plugs revealed nothing cause it’s not ran at WOT all the time
Old 03-27-2025, 12:45 AM
Jay S's Avatar
Jay S Jay S is offline
If it is detonating you should fine small aluminum freckles on the porcelain of the electrode.
That NGK plug you list is already a pretty cold plug. Going colder than that won’t gain anything.
Old 03-27-2025, 07:31 AM
Jay S's Avatar
That top line should say find, not fine. Sorry about that.
Old 03-27-2025, 03:59 PM
HWYSTR455's Avatar
You should post pics of your plugs and see what others think.
Did you get the carb and timing dialed in?
Old 03-27-2025, 04:45 PM
Formulas Formulas is offline
If a colder plug helps you out and doesn't foul ... good on ya .. This group does not allow such operations
If your not at the table you're on the menu
Old 03-27-2025, 05:29 PM
HWYSTR455's Avatar
I would agree with that possibly if I actually saw a plug, but not going to go off heresy.
If the tune is off the heat range ain't gonna tell you jack.
Old 03-28-2025, 02:10 AM
NeighborsComplaint's Avatar
Hard to hear detonation over the loud exhaust and roller rockers. Plugs would look gray with aluminum specs on the porcelain like others have said. If you borrow or buy a borescope, you will see pitting on the piston tops instead of carbon buildup.
When you lug the motor down in overdrive on a slight incline, you should be able to hear it ping over the exhaust at light throttle. Does it diesel when shut off?
Triple Black 1971 GTO
Old 03-28-2025, 05:16 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
As already stated, look at plugs for aluminum specks on the porcelain. Look with a magnifying glass. A friend of mine was talking about how his engine ran fine on 87 octane. I suggested looking at a plug. It was coated with AL.
Old 03-28-2025, 06:04 AM
If your detonating with aluminum heads they do show more aluminum transfer to the plugs since your blasting material off both the Pistons and heads .
however if you find a lot of aluminum transfer with iron heads then your Pistons should look like Hell and your rod bearings on the cylinders that are detonating are likely well on there way out depending on the rpm the motor was being run to while detonating and you may have busted some rings if the motor is using oil.
And if it is using oil then the exasperates the detonation condition .
Old 03-28-2025, 07:24 AM
Kenth's Avatar
Kenth Kenth is offline
Lugging the engine in overdrive at low speeds will make any engine ping.
Changing plugs is no remedy, shifting gears is.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-28-2025, 07:33 AM
grivera's Avatar
grivera grivera is offline
What is your compression?
Will Rivera
‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.90 gears, work in progress
'69 LeMans Vert, 350, #47 heads, TH400, 10 Bolt 3.90 gears, work in progress
Old 03-28-2025, 08:00 AM
64speed's Avatar
10.25 is compression. I don’t lug the engine.
Old 03-28-2025, 01:24 PM
Kenth's Avatar
Too fast centrifugal ignition advance?
Too lean carburetor?
Too rich carburetor?
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Thread Tools
Display Modes
