Old 10-31-2007, 09:59 AM
TEG's Avatar
TEG TEG is offline
Default Transmission Stencil/Code
Can anyone tell me what letters would have been stenciled onto a Muncie M-20 transmission? 1969 car. Was it a light yellow color? Where would the stencil be on the transmission?
Old 10-31-2007, 10:02 AM
Mark Simiele's Avatar
Mark Simiele Mark Simiele is offline
I know light yellow was on the THM400 auto trans tag and it said PX and the vin.
Old 10-31-2007, 10:16 AM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
Ok misunderstood the inital question.
John
John
Email jbr69gto@gmail.com
My Website www.minnesota-muscle.com
Old 10-31-2007, 10:21 AM
gloryrestoparts's Avatar
gloryrestoparts gloryrestoparts is offline
thats the vin derivative stamping, to me thats not a stencil. If I'm reading this correctly, he's asking about the 2 letter code that is in ink on the main case. I don't have my book in front of me, but Eric White's GTO/GT-37 book lists the information you seek.
http://gloryrestoparts.20megsfree.com/
1970.5 Pontiac Tempest GT-37
400ci 4bbl 4sp 3.90:1
12.73 @ 112.42 2011 Pure Stock Drags
12.71 @ 110.58 2013 Martin FAST/FS race
12.70 @ 111.74 2014 Pure Stock Drags
12.60 @ 111.66 2015 Martin FAST/FS race
1968 Pontiac Firebird 400
TH400/3.08 open
export car - factory heater delete
14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags
14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race
Old 10-31-2007, 10:30 AM
TEG's Avatar
TEG TEG is offline
Default Yellow Stencil
Thanks John. I have the VIN, however, I am looking for the right 2 letter yellow code that would have been lightly stenciled onto the transmission case. Again, thank you for the help.
Old 10-31-2007, 10:34 AM
LPete LPete is offline
That should be in the factory assembly manual. I'll check this morning if no one else answers.
Lee Peterson
"I didn't expect a kind of Spanish Inquisition...!"
'69 Cameo White RA III Judge, 4 speed, owned since 1977 -- my first car.
Old 10-31-2007, 10:37 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
From Eric's GTO/GT-37 book, a 1969 GTO M20 would have had a two-letter code of "FO" stenciled on top of the main case.
HTH!
Regards,
"455HO" Lloyd
Old 10-31-2007, 12:17 PM
TEG's Avatar
TEG TEG is offline
Default Stencil
Thanks Lloyd. I believe that was a 2" stencil?
FYI--I will be photographing the head bolts and posting tonight or tomorrow.
Old 10-31-2007, 01:06 PM
RAIVJUDGE's Avatar
RAIVJUDGE RAIVJUDGE is offline
The stencils (pick codes for the assembly line workers) are supposed to be on the top of the transmission and could not be seen when the trans was installed in the car. many restorers put the two letter stencil codes on the passenger side of the trans so that judges and people that are viewing the cars can see them.
Old 10-31-2007, 01:11 PM
UPC-WU2's Avatar
UPC-WU2 UPC-WU2 is offline
My M40 had a two-letter code (PQ) in pink letters and looked like it was applied with a big rubber stamp. Letters were about 3-inches high.
1971 GT-37 - 350/M38, Rosewood Metallic/Black
www.GT-37.org
Old 10-31-2007, 02:06 PM
dr-doug's Avatar
dr-doug dr-doug is offline
Here's the original off my '71, turquoise PQ had a line in front of the PQ that looked like the edge of a rubber stamp that got the paint on it also and transfered. I actually traced it out on a piece of paper so I could reproduce it correctly. Manual trans may have been on the top, but as you can see this was more down the side....DW
71 SILVER AUTO JUDGE
70 RED AUTO III JUDGE
70 GOLD AUTO III JUDGE
70 SPECIAL ORDER SABLE BLACK 4SPEED III JUDGE
70 ATOLE BLUE AUTO GTO
69 C.RED 4SPEED III JUDGE
67 WHITE 4SPEED 400 VERT FIREBIRD
65 MAIZE 4SPEED TRIPOWER VERT GTO
65 TURQ. 4SPEED TRIPOWER VERT GTO
WANTING A IV......
20 other non-pontiacs which need to be thinned down so I can buy more PONTIACS
Old 10-31-2007, 02:29 PM
UPC-WU2's Avatar
Here's mine after I made a rubber stamp and re-applied the code. Mine was pink.
www.GT-37.org
Old 10-31-2007, 05:40 PM
RAIVJUDGE's Avatar
That's exactly where I found the markings on the automatic convertible Judge I owned at one time. It seems the autos were more down the side like you state and the manuals were on top.
Nice detail work BTW
Old 10-31-2007, 09:23 PM
Love that stamp!
Old 11-01-2007, 12:26 PM
SWEETJUDGE's Avatar
SWEETJUDGE SWEETJUDGE is offline
I HAVE & MAKE THEM...........
Old 11-05-2007, 02:54 PM
racerboy's Avatar
racerboy racerboy is offline
Attachment 109818
UPC-
I don't mean to hijack the thread, but color black did you use on your firewall/heater box/frame? I have the entrie front clip and suspension out of my '70 Judge (was all painted a high-gloss black by previous owner) and want it to look correct (your's looks great).
Frank
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 11-05-2007, 03:51 PM
UPC-WU2's Avatar
Frank, thank you. I used a good urethane enamel and went about 50/50 with the flattener and shot it with a good gun. It was trial and error as far as the amount of flattener but I think it looks about right. The frame and A-arm are actually rather dusty in that picture. Those underhood components should not be gloss black.
www.GT-37.org
Old 11-05-2007, 03:56 PM
UPC-WU2's Avatar
Here's another shot. I messed up the air cleaner lid (dust) and had to re-shoot it. Top of the dash is flat black.
www.GT-37.org
Old 11-05-2007, 04:25 PM
racerboy's Avatar
And if you were trying to replicate that with a rattle-can, any suggestions? I have heard that the heater box and fenderwells and frame should be same gloss, and the firewall should be less glossy.
Old 11-06-2007, 08:30 AM
UPC-WU2's Avatar
Krylon makes a "Semi-Flat" black rattle can that looks right for that kind of stuff.
www.GT-37.org
