Old 12-31-2016, 07:37 PM
potentpontiac's Avatar
potentpontiac potentpontiac is offline
Default Gas Ports
Any advantage to using Vertical Gas Ports VS Horizontal for better ring seal. NA Application. Low tension rings like the Gas ports along with a Good Vacuum pump system to seal up the pings in the bore.
Old 12-31-2016, 08:44 PM
Half-Inch Stud's Avatar
...seal up the rings in the bore. eh.
Probably a requirement for N2O
Probably a mandatory requirement for RPM > ~ 6200-6500
Not an exspert
Old 12-31-2016, 09:03 PM
OOPS. Should check my spelling EH !!! Just wondered if either Vertical or Horizontal Gas ported pistons have any distinct advantage in better ring seal. Happy New Year !!!
Old 12-31-2016, 09:48 PM
Tom Vaught's Avatar
Boost Engineer
Vertical will tend to plug up easier as more carbon formation on the crown vs on the roof of the upper ring land.
Tom V.
Old 01-01-2017, 08:26 AM
Thumbs up
That's what I was thinking Tom. Happy New Year to you.
