#61
ours runs fine on 93 octane and a few gallons of low lead 100 octane av fuel mixed in
Frank Szymkowski 1969 GTO Judge Warwick blue/blue, RAIII, 4 speed, tach/gauges, Safe T track, 3.55's, ps and radio. 1971 Torino 351c 4v GT convertible. White on white with black interior 4 speed, shaker, am/fm, ps/pdb, buckets/console, ac. One of 26 made |
#62
Stan
#63
and that is EXACTLY what the 1970 Performance catalog put them at.
#64
What are the implications of say using the 1973-1974 SD 455 style single trough valve relief piston design, as well as the weird silence on that design, especially given Pontiac's devotion to tweaking the designs of their engines with numerous cylinder head revisions?
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads 1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455". What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere? |
#65
Stan, did not do a cranking compression test. Why? (BTW we are right over the bridge in jersey)
#66
Many years ago I worked for a number years at a few different jobs in Cinnaminson . Stan
#67
No, my engine has been rebuilt to stock specs. Where in Cinnaminson?
#68
I am bad with street names, so I hope I have the right one. I believe it was Riverton Rd and Rt130, there was a Gulf Gas Station that I worked at. It had a jug handle around it. Next if you head up Riverton Rd I did some work late in the Wellington housing development and then at the Wellington of Moorestown development. After that if you are on RT130 N right pass the jug handle (from the above gas station) on the right is a small office complex. I worked for a company that had an office in that complex for a few years. All of this was back in the 60's and 70's Stan
#69
I was still a Chevy guy back then! Bought the 614s in late 80s after my 78 TA got beat bad at the track bu a just warmed over 5.0 later Mustang.
#70
#71
Dished pistons and a custom cam and you can run 91.
