Old 11-16-2023, 10:24 AM
MDSHARK81 MDSHARK81 is offline
Default Back Lock (Reverse Lock) set up for 71 T/A with M-22 trans-installed on car Pics Pls
I am Finally getting my 71 Trans am back together. It's a 4 speed car, and when I got it, the back lock system was gone. Fairly common I understand. I see that Ames has most of the (repop) components needed to get the system installed and working in the car. Does anyone have pictures of their 4 speed Muncie cars with this system installed. I need to get an understanding of how it works and exactly what I'm missing and need to find and install. Thanks All !!!
Old 11-16-2023, 12:27 PM
unruhjonny's Avatar
I will look, but I don't believe I have any good pictures.
It's all exactly the same as any 1970-1974.5 Firebird or Camaro with a Muncie four speed.
I know that there are threads with people looking for parts, and pictures over on 'nastyz28' - I was able to confirm via discussions over there what reverse lockout rods I have.
1970 Formula 400
Old 11-16-2023, 01:02 PM
AG's Avatar
AG AG is offline
I have a back lock system from a 1971 TA 4 speed. I'll take pics and post by tomorrow.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 11-16-2023, 02:03 PM
Worth checking the STICKY threads in this section for prev posted pics.
At least 3 PY members have extensive threads on their '71 & 72 4 speed T/A restorations.
Old 11-16-2023, 06:07 PM
AG's Avatar
AG AG is offline
Here are pics of mine. I took it off a 1971 TA.
ID:	623359   Click image for larger version
ID:	623360   Click image for larger version
Old 11-16-2023, 09:04 PM
hiyabradHO hiyabradHO is offline
Can someone please explain what the back lock system does?
Old 11-16-2023, 10:09 PM
The existence of, as well as the proper adjustment of, the back drive linkage allow the backup light switch to be activated when the transmission is in reverse. Back up light switches began being installed on the columns of '69 & later manual transmission cars, '68 on automatic trans (non GTO) A-body's. Manual trans cars used the smaller backup light switch down low on the column.
Old 11-17-2023, 12:26 PM
nas t eh nas t eh is offline
The other purpose is to lock the car in Reverse before being able to remove the key from the steering column
73 T/A 455, 4speed
The Following 2 Users Say Thank You to nas t eh For This Useful Post:
Old 11-20-2023, 08:36 AM
Does anyone have this system installed and working in their 4 speed cars???
Old 11-30-2023, 09:55 AM
Wow, I can't believe that no one has this system installed and working in their 4-speed cars. Is it that much of a pain to use?
Old 11-30-2023, 10:34 AM
I have headers on mine, not very compatable. Future low priority project to modify linkage to work..
73 T/A 455, 4speed
The Following User Says Thank You to nas t eh For This Useful Post:
Old 11-30-2023, 11:06 AM
72projectbird's Avatar
I do. It works good. Makes the reverse lights turn on, and makes it so you can't get the key out unless the car is in reverse. Works flawlessly. It's pretty cool to have everything working.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 11-30-2023, 11:35 AM
unruhjonny's Avatar
I think you're quite mistaken.
OPH posted (post #4) rightly that there are stickied threads where these images can be found.
You are asking for someone to crawl under their car and take pictures of something for you when the same type of image can already be found here (and elsewhere).
1970 Formula 400
Old 11-30-2023, 11:48 AM
starlightblack's Avatar
starlightblack starlightblack is offline
"Spend all your time and money on that Pontiac GTO pile" - The Go-Gos, 1981
Old 11-30-2023, 05:12 PM
My intent was NOT to inconvenience anyone. My expectation was that many here like me have a digital library of their cars restoration stored on flash or hard drives, which can be accessed while on the forum.
Thank you Starlight for the exploded diagram I will consult it when replacing my back lock system.
I also enjoy having every system installed and working as intended on my cars. I thought this topic was an interesting quirk of these cars to discuss.
Old 12-04-2023, 06:29 PM
Does this help?
Picture 1 shows the inside of the driver side frame rail where the pivot attaches with three screws/bolts.
Picture 2 is of the pivot.
Picture three shows the pivot in place.
Picture 4 shows the back drive rod from the shifter to the pivot. (FYI, the backdrive rod goes into the bottom hole of the shifter's reverse rod).
Picture 5 is just another angle of the back drive rod.
Name:	Backdrive bracket point on subframe.jpg
ID:	624392   Click image for larger version
ID:	624393   Click image for larger version
ID:	624394   Click image for larger version
ID:	624395   Click image for larger version
Old 12-04-2023, 06:39 PM
Here are some more pictures.
Picture 1 is of the aftermarket back drive setup which is available from our host (Ames Performance). Their part number is FR685B. You might also need an "Upper Steering Column Lock Rod Swivel Assembly" to attach the rod that goes up to the steering column. The Ames part number is FR683K.
Picture 2 and 3 are of an aftermarket back drive rod sitting next to an original rod. The ends are different (aftermarket rod has a shoulder on it), but functionally they are the same. The aftermarket rod is the same length and has the correct bend, so it will work just fine.
ID:	624397   Click image for larger version
ID:	624398   Click image for larger version
Old 12-04-2023, 07:34 PM
The first group of pics were the money! Where the pivot attaches to the frame rail, and the tip using the bottom reverse rod hole. Sometimes a picture really is worth a thousand words. Really helpful. Thanks!
