Old 12-03-2017, 12:05 AM
Carl S Carl S is offline
Default 66 factory tach wire connection at the firewall
Does anyone here have a way to post a picture of the brown wire that goes to the coil where it comes through the firewall on a 66 full size?
My 66 assembly manual has it drawn as kind of a square or rectangular connection but I thought it was a grommet similar to the back up lamp wire grommet in the trunk floor. I know assembly manuals to be pretty accurate normally but I'm not trusting it this time.
This is on a Canadian car but I am betting it will be the same, the tach is identical.
Thanks.
Old 12-06-2017, 11:45 AM
70ra455's Avatar
70ra455 70ra455 is offline
I will try to get pics.
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console
1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats
2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather
Old 12-07-2017, 02:26 AM
That would be excellent, thanks. You have a factory tach car?
Old 12-11-2017, 01:15 PM
69TA-vert 69TA-vert is offline
This ?
ID:	469879   Click image for larger version
Old 12-11-2017, 02:06 PM
Is that on a 66 full size Pontiac? That's not at all what I was expecting. I thought it was a connection through the firewall over beside the brake booster.
Old 12-11-2017, 04:30 PM
Am I getting closer ? Yes it is a 66 Bonneville 421 HO with factory tach.
ID:	469884   Click image for larger version
ID:	469885   Click image for larger version
Old 12-11-2017, 04:36 PM
Yes, that looks similar to the drawing in the assembly manual. Wow, I've never seen anything like it. That isn't reproduced that you know of, is it?
And thank you very much for doing that.
Old 12-11-2017, 05:55 PM
No idea if it's reproduced. That one was NOS from Ebay.
Old 12-11-2017, 06:43 PM
part # 9776918
Old 12-12-2017, 02:08 AM
This was all I had to go by. (Hopefully the picture attaches). It's the drawing from the 66 B body assembly manual.
I could tell it was beside the two firewall harness connectors and that is was rectangular, that was all. It's in the picture, lower right, just above the text box at the bottom of the page. Sure looks like what you posted. Thanks very much once again.
Old 12-27-2017, 02:57 AM
One more tach question. I can't find the fuse size listed anywhere. I am trying to figure out what fuse goes in the fuse holder that comes off the ignition coil.
Old 12-27-2017, 07:11 AM
Old Goat 67's Avatar
Should be 1 amp.
Old 12-27-2017, 09:27 AM
Excellent, thank you.
Old 12-30-2017, 12:58 AM
70ra455's Avatar
69TA what is that connector behind the distributor? I'm rewiring my car with a tach and don't remember that?
Old 01-01-2018, 11:51 AM
That's just a junction box for cars with Transistorized Ignition.
Old 01-01-2018, 03:40 PM
70ra455's Avatar
Phew! Lol
