66 factory tach wire connection at the firewall
Does anyone here have a way to post a picture of the brown wire that goes to the coil where it comes through the firewall on a 66 full size?
My 66 assembly manual has it drawn as kind of a square or rectangular connection but I thought it was a grommet similar to the back up lamp wire grommet in the trunk floor. I know assembly manuals to be pretty accurate normally but I'm not trusting it this time. This is on a Canadian car but I am betting it will be the same, the tach is identical. Thanks. |
I will try to get pics.
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console 1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats 2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather |
That would be excellent, thanks. You have a factory tach car?
This ?
Is that on a 66 full size Pontiac? That's not at all what I was expecting. I thought it was a connection through the firewall over beside the brake booster.
Am I getting closer ? Yes it is a 66 Bonneville 421 HO with factory tach.
Yes, that looks similar to the drawing in the assembly manual. Wow, I've never seen anything like it. That isn't reproduced that you know of, is it?
And thank you very much for doing that.
No idea if it's reproduced. That one was NOS from Ebay.
part # 9776918
This was all I had to go by. (Hopefully the picture attaches). It's the drawing from the 66 B body assembly manual.
I could tell it was beside the two firewall harness connectors and that is was rectangular, that was all. It's in the picture, lower right, just above the text box at the bottom of the page. Sure looks like what you posted. Thanks very much once again. |
One more tach question. I can't find the fuse size listed anywhere. I am trying to figure out what fuse goes in the fuse holder that comes off the ignition coil.
Should be 1 amp.
Excellent, thank you.
69TA what is that connector behind the distributor? I'm rewiring my car with a tach and don't remember that?
That's just a junction box for cars with Transistorized Ignition.
Phew! Lol
