Old 08-08-2022, 09:12 PM
67drake's Avatar
67drake 67drake is offline
Default Canned piston rings anybody?
I just picked these up. A can of Chevy piston rings for a ‘33. I’ve never seen such a thing!
13.95 @ 102.1 on street tires @ 4055lbs.
Old 08-08-2022, 09:33 PM
Sirrotica's Avatar
Is there an expiration date on the can?.......
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-08-2022, 10:04 PM
vr1967 vr1967 is offline
Are they powdered? Just add oil?
Cool find. I’ve never seen such
Old 08-09-2022, 01:22 AM
Jack Gifford's Avatar
Jack Gifford Jack Gifford is online now
formerly 'Pontiac Jack'
Old stuff is interesting.
The manual for my 1917 Buick has instructions for replacing a broken piston ring- without removing the head! Pull the pan, unbolt the rod cap, and remove the rod and piston out the bottom- since the crank has no counterweights to be in the way. Find a tin can larger than the piston, slit it, and wrap it around the piston to guide the rings into the cylinder.
The Following User Says Thank You to Jack Gifford For This Useful Post:
Old 08-09-2022, 04:54 AM
dataway's Avatar
dataway dataway is offline
Jack ... since it sounds like you are into the really old cars ... how is the NOS parts supply for the very common models from the 30's? Not just Pontiacs but other marques too. Always wondered about that.
Old 08-09-2022, 09:36 AM
mgarblik mgarblik is offline
Can-o-piston rings! Very cool. Love the Chevy Bow-tie at the top. "Hey Mac, run to the parts counter and get me a couple muffler bearings and a can of piston rings".
Old 08-09-2022, 10:26 AM
John V. John V. is offline
McQuay-Norris Manufacturing Co. was a manufacturer of piston rings that packaged sets in same type containers under their own name.
Don't know if they were an Original Equipment supplier to Chevy or any other OEM but seems possible.
There are a handful of similar sets in McQuay-Norris cans on eBay.
Would make for a fun display for anybody having a vintage service station replica.
You need to pick up a junk disassembled 1933 Chevy 6 and display it along with the ring set can. A classic round tuit work in progress!
The Following User Says Thank You to John V. For This Useful Post:
Old 08-09-2022, 04:09 PM
unruhjonny's Avatar
that is neat!
Thanks for sharing this!
1970 Formula 400
Old 08-09-2022, 04:40 PM
geeteeohguy's Avatar
Right next to the bar code.
Jeff
Old 08-09-2022, 08:43 PM
unruhjonny's Avatar
BAH-HA-HA!!
1970 Formula 400
Old 08-09-2022, 10:44 PM
skipp65 skipp65 is offline
Add a can of compression while you’re at it.
Old 08-10-2022, 02:08 AM
Heybuck's Avatar
Heybuck Heybuck is offline
What you aren't saying here Jack is you cannot remove the head. The head is all cast into the block which is great insofar as you don't have to worry about head gaskets.
Several years back I helped my more senior friend work on his 1916 Buick DX44. I very clearly recall removing that huge cast alloy sump and pulling off the rod caps so he could measure the bearings. What a mess.
Also pulling out the gearbox so he could fit a new cone clutch in it. Would you believe he had a contact in New Zealand who had NOS bearings and a NOS cone clutch on his shelf.
To laugh at men of sense is the privilege of fools.
The Following User Says Thank You to Heybuck For This Useful Post:
Old 08-10-2022, 03:29 AM
242177P's Avatar
242177P 242177P is offline
Originally Posted by Heybuck View Post
... head is all cast into the block ...
Had to look, because headless sounds like an interesting casting.
Looks like they made some big changes for the 'new' '17s.
Name:	1916 Buick.jpg
ID:	596191   Click image for larger version
Name:	1917 Buick.jpg
