78-81 Pontiac Motor Mount Brackets
Is there a diference between Late F-Body 3-bolt Pontiac Motor mount Brackets 75-81 and the Brackets used on 78-81 Pontiac 301 a & G Bodies?
I ask as a freind is putting a 400 Pontiac in his 83 Bonneville G Wagon. And I have a set of brackets that are either from a 79 301 powered Firebird, or a 301 Powered 1980 GP. I didn't seem to tag them and now 10 years later can't remember.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
Forgot to add the pic's of what I have. Sorry
The g body brackets are different. They should have part numbers stamped into them. The pic is the mounts from my '80 Lemans 301.
'80 Grand Lemans Was 301 C.I. Will be bigger soon. 00 GTP NBM / Graphite, Stock Sold Aug. 2011 70 GTO Black / Black TH400 460 CID, 542 FWHP, 580 FWTQ (Sold, Fall '09) 04 GTO Black / Black M6 Back to bone stock and sold, fall '05. |
Thanks for the reply, the ones I have must be 77-81 F-body
time for repro?
recently saw a set of the bird shells for sale on ebay for $100. they were just cleaned up & painted. 2 me this is ridiculous ! isn't it about time for somebody 2 make a repro? there's not much 2 em, so a cheap chinese repro should be a good seller with a reasonable price. or maybe somebody already has em & i'm the last 2 know. do ya'll know of any?
The Fbody one will work but raise the engine higher which is not good since Gbodies are hood clearance limited already.
The Fbody ones have an F stamped on them also. Give me a reminder in a week or 2, I my have a extra set of Gbody ones. Moving my shop now and can't find a damn thing!!!
"resurfacing Pa highways 2 long black strips at a time" 78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z Best to date 10.00@130.92 mph at 3250# 79 Grand Prix, will be new home for the 440 Goal 9.75z@135mph at 2900# 83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z Making it the Ultimate Utility Vehicle Go, tow and show (not so much show, yet) |
mounts
get 3 pair left if you still need them.
I would be interested in a set. I am putting a stroker 400 in a 1986 Grand Prix 2+2.
The F-body and big car ones also make your header situation worse. They appear to be just like the 78-81 G-body mounts until they are side by side. Then you can see the difference. I have a set of Indian Adventures mounts that will allow the use of an early or late block. I need to draw them up in CAD so I could get a few made.
