Old 08-13-2020, 08:13 PM
Whee30 Whee30 is offline
Default Will Ames 65-65 big car steering wheel fit 63 big car
I’m wanting to change the steering wheel my 63 GP. The car is in stock form so
I’m wanting to go with a wood wheel that looks stock even though the 63
didn’t have this type . The clear wheel I have on it has the usual cracks and splits.
Old 08-14-2020, 06:03 PM
webfoot's Avatar
webfoot webfoot is offline
You could bolt a steering wheel off a 1991 blazer onto your 63. Saginaw steering column shaft end was the same for a long time. The difference is the width of the column, thru 68 (cars) the ignition was in the dash and should be all the same diameter. After 68 it was integrated into the column and they are a bit wider.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 08-14-2020, 08:28 PM
Default Makes sense
Thanks for the info.
