Door hinge interchange?
Will front lower door hinge from a 61 Catalina sedan....fit my 63 Safari?
Also.....what is first year for self adjusting brakes? Thanks for any input.. |
p/n 4309530 right hand lower hinge, p/n 4309351 left hand lower hinge
fits all full size 1961 through 1964. The first mention of self adjusting brakes in the factory brochures was in 1963. |
1966 Chassis Parts Catalog shows parts for self adjusters starting in 1963.
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
Thanks.....for the info...
I looked at the hinges....and they looked the same....just wanted to make sure....before I pulled them..... It appears that door needs to come off....and lower portion of fender needs to be unbolted? This 63 has NO self-adjusting hardware....so I am assuming previous owner didn't like the concept... |
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
Well that is good to know....
My cowl tag is stamped 01B.........Which is January,I believe.... Body # is BC 438 Looks like an early body #....but from January? |
When I first started work as a mechanic self adjusting brakes had only been out a few years and people didn't trust them. Whenever we did the first brake job on a car that had self adjusters we removed them. Simple job.
