Old 10-12-2021, 07:40 PM
69Y97GP 69Y97GP is offline
Default 1970 GTO For Sale
1970 GTO. Base 400 with SR Block. Original M20 just rebuilt. #12 heads just rebuilt with new valves, springs, guides etc. 3.90 10 bolt rear with Auburn posi with maybe 1000 miles. I rebuilt the Chassis a couple years ago with a beautiful Georgia frame, new springs, bushings etc. The body mounts are terrible so I have an extra body that is very solid but will still need quarters. Have lots of extra parts like Endura nose, door panels, Instrument trim, all the vinyl top trim (because I was going to put it back to original). $12,500.00 In Livonia, MI
ID:	575007   Click image for larger version
ID:	575008   Click image for larger version
ID:	575009   Click image for larger version
ID:	575010   Click image for larger version
Old 10-12-2021, 07:44 PM
Default 1970 GTO More Pics
Pics
ID:	575012   Click image for larger version
ID:	575013   Click image for larger version
ID:	575014   Click image for larger version
ID:	575015   Click image for larger version
Old 10-12-2021, 07:47 PM
Default 1970 GTO EXTRA BODY PICS
Extra Body....
ID:	575017   Click image for larger version
ID:	575018   Click image for larger version
ID:	575019   Click image for larger version
ID:	575020   Click image for larger version
Old 10-12-2021, 07:49 PM
Default 1970 GTO WINDOW STICKER
WINDOW STICKER
ID:	575022   Click image for larger version
Old 10-20-2021, 05:18 PM
Default Price Drop to $10,000
I must be too high on the price. The car runs and drives good, just really needs to have the body done. Otherwise it's a decent car for the money considering everything that comes with.
Old 10-21-2021, 02:27 AM
Default Your price is not really too high.
PYers are notoriously cheap bastards - me included.
You'll probably do better with this on FB marketplace or CL.
Good luck!
Old 10-21-2021, 08:45 PM
tt455's Avatar
tt455 tt455 is offline
I like the car, it's something I'm interested in and it's probably me, but I'm a little confused. The frame is good but when you say body mounts are you saying the actual body holes are bad? Is this the only reason for the extra body? What was wrong with the old frame? Is the body on the car now salvageable? Sorry if I missed something. Thanks
Tom
1971 Buick GS 455 Stage 1
Old 10-21-2021, 11:53 PM
Default 70 GTO story....
When I bought the car all the suspension bushings were pretty shot so I decided to replace them and the springs at the same time. My original plan was to restore the car so I pulled the body off. The underbody reinforcements that hold the cage nuts were all pretty rotted except for a few, and the frame didn't appear straight, like maybe it had been hit and repaired at some time, and had rusty mounting holes also, so I got a much better Georgia frame for it, did the bushings, springs etc, put the body back on and got a $400 Maaco paint job to make it look decent for summer of 2018.
Aside from the rotted cage nut/floor supports the floorpan itself isn't that bad but the rockers have holes on the tops and there's a lot of filler in the body and the panel between the rear window and decklid is bad. It was a vinyl top car but a previous owner removed it and cut all the trim studs off. So, I found a solid body ('72) in colorado with great floors, rockers, roof, trunk floor and all the trim studs for a vinyl top. That body does need quarters because there is rust around both wheel openings. I suppose the original body could be saved but will require lots of work, so I think it's easier to use the 2nd body because its so much more solid and still has all the studs for the top trim. The car runs and drives decent. Has a 3.90 with Auburn posi (4 yrs old). M20 trans just rebuilt, new clutch, the #12 heads just redone w/ new valves, springs etc. I have a complete nice LH quarter, rear valance, new repop splitters, new front valance, nice extra nose, a pontiac 12 bolt, uncut cluster trim and more. The hood tach doesnt work...haven't looked into why. Have the PHS... I had every intention of restoring it but I'm trying to get my '69 GP back together and then 2 years ago I bought a '70 Formula 400 at Mecum Las Vegas that I now drive...so the GTO just doesn't fit in the plan anymore. I'm open to offers but won't give it away either. I can send pics of particular areas but will take a day or 2. Thanks...
Old 10-23-2021, 12:49 PM
origional exterior color?
Old 10-23-2021, 02:57 PM
Good question maybe?
The PHS posted is Palladium Silver, but may be for the extra body?
Old 10-23-2021, 03:10 PM
PHS is for the GTO. it was Palladium Silver with Black Vinyl top and Black interior. The extra body is from '72 LeMans with AC.
Originally Posted by Half-Inch Stud View Post
original exterior color?
Old 10-23-2021, 06:18 PM
Default MORE PICS
Underside of the car...
ID:	575946   Click image for larger version
ID:	575947   Click image for larger version
ID:	575948   Click image for larger version
ID:	575949   Click image for larger version
Old 10-23-2021, 06:20 PM
Default still more pics
more underside pics
ID:	575951   Click image for larger version
ID:	575952   Click image for larger version
ID:	575953   Click image for larger version
ID:	575954   Click image for larger version
Old 10-23-2021, 06:24 PM
Default and even more pics
few more
ID:	575956   Click image for larger version
ID:	575957   Click image for larger version
ID:	575958   Click image for larger version
ID:	575959   Click image for larger version
Old 10-23-2021, 06:27 PM
Default final pics
body pics
ID:	575961   Click image for larger version
ID:	575962   Click image for larger version
ID:	575963   Click image for larger version
ID:	575964   Click image for larger version
Old 01-16-2022, 11:30 AM
Default GTO IS SOLD
SOLD SOLD SOLD
