Old 10-09-2021, 01:18 PM
shawn e.'s Avatar
shawn e. shawn e. is offline
Default Check out this combo!
https://medford.craigslist.org/cto/d...385900498.html Astre with toyota diesel motor.
"Don't let fatigue make a coward of you."
The Following User Says Thank You to shawn e. For This Useful Post:
Old 10-09-2021, 02:28 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Has no idea there was such a thing. Would make a great sleeper with a Pontiac V-8 between the frame rails.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet.
The Following User Says Thank You to prostreet64 For This Useful Post:
Old 10-10-2021, 12:50 AM
That is pretty amazing with a diesel engine in it.
I am leaning way towards it being a conversion.
VW didn't start sending diesels to the USA until about 1977 iirc
Not at all familiar with toyota diesel engines and can't tell for sure if that engine is turbo-charged or not. but appears it is not
Old 10-10-2021, 05:45 AM
59safaricat 59safaricat is offline
Looks like their L series engine, probably a 2L. Also appears to be non turbo. At least it'll be reliable and get a minimum of 40+ MPG but will be painfully slow for those accustomed to modern gas engines and instant acceleration of the past 30+ years.
Old 10-10-2021, 07:59 AM
Stuart's Avatar
Stuart Stuart is offline
It has to be a conversion by someone, although it looks like it was done very well.
The Pontiac T1000 was available with a diesel engine but it was sourced from Isuzu.
Old 10-10-2021, 08:47 PM
Ad not available until the 1980's I beleive. This is a unique conversion. Would not be fast but should get 30+ MPG
Old 10-11-2021, 12:11 AM
77 TRASHCAN's Avatar
A good friend of mine had a diesel Ford Escort. Sounds like it was a pile, it it ran and drove great!!! 50 MPG, was a Mazda Diesel engine. When ever we talk about that car, I always tell him, he should have kept it!!!
Shut it off
Shut it off
Old 10-11-2021, 07:55 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
The engine compartment of the H-Body (it was H until that was later reused on the Bonneville/Lesabre/etc FWD cars) was designed to accommodate a rotary engine whose program and partnership never materialized. The 4cyl (2300s) were easy to work on, which was handy because they were unreliable. The v6 cars werent bad, but the pre 77 cars were odd fire without the split crankpin and shook like a dog crapping peach pits. Those SBC versions were a nightmare to work on, and obviously the inspiration of the 82-92 Fbody engine compartment - I think the only change for the F-body was to add more sharp edges to tear your hands up on.
Clutch Guys Matter
_______________________________________
53 Studebaker, 400P/th400/9"
64 F-85
72 4-4-2 Mondello's VO Twister II
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 10-11-2021, 02:03 PM
android 211 android 211 is offline
A college friend had a diesel Chevette his parents bought him. It got around 50mpg. I don't know where Chevy sourced the engine. It was noisy.
I had a diesel Rabbit pickup. I ran out of fuel twice because I forgot to put in fuel because I had a short drive to work and a tank lasted me weeks at a time.
Old 10-11-2021, 02:11 PM
67drake's Avatar
67drake 67drake is offline
I remember a guy at my high school had a diesel rabbit. I bummed a ride home from him once and two of my buddies jumped in too. We laughed the whole trip as the owner held his foot to the floor continuously just to try to get it up to the speed limit.
13.95 @ 102.1 on street tires @ 4055lbs.
