Old 10-13-2021, 11:41 PM
getmygoat's Avatar
Default 1970 GTO thoughts?
Hi all,
Just curious if anyone knows this car or sees anything out of place. The VIN doesn't look like a correct stamp to me but I'm not an expert on Texas stamping.
Thanks!
https://bringatrailer.com/listing/19...o-ram-air-iii/
Old 10-14-2021, 01:08 AM
Glove box door fitment is janky and mufflers are same length, but other than that this was superbly done.
The color combo is quite nice.
Old 10-14-2021, 03:05 AM
Kenth's Avatar
Kenth Kenth is offline
FYI, mufflers for 1970-72 GTO are the same lenght from factory.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 10-14-2021, 10:36 AM
pggto's Avatar
pggto pggto is offline
It looks like it has a dash cover on it by the way it fits around the glove box and dash bezel.
Old 10-14-2021, 10:48 AM
pggto's Avatar
Nice car! That car has a nice list of options.
Are you looking for inaccuracies as a buyer?
I see it has a reclining seat on the passengers side. Are the seat releases different for the seats? The release button on the standard seats is in the center of the back, this one has the release on the side. Is this correct?
I think it has the wrong wood grain on the dash and front console, I thought 70 looked more like the wood grain on the shifter bezel?
It looks to me like it has a dash cap on it.
Old 10-14-2021, 12:08 PM
getmygoat's Avatar
Also has a stainless steel gas tank which is of course not correct.
Somewhat concerned about the VIN stamp. Don't they usually run vertically?
Old 10-14-2021, 01:20 PM
Most run vertical. But it is a Fremont car, they seem to be 'different'.
The partial vin though should start with '20Z' not '70Z'?
Plus the 'Z' looks really big.
Doesn't appear to be ground, so might be a non-stamped block?
Old 10-14-2021, 03:55 PM
tigergto's Avatar
tigergto tigergto is offline
Looks like the dash appliqué from a 71. The wood grain on the shifter bezel is correct. Weird they would use the appliqué from a 71. They are much scarcer than a 70.
Old 10-16-2021, 08:24 AM
scott70's Avatar
scott70 scott70 is offline
Not that I care but its the little things like not many people ever seem to get the fender decals in the right place and almost always use the wrong trunk decals and also get it in the wrong place. Also the factory used black decals against the mint turquoise paint which to me looks better than white.
But it looks like a nice car from here,well optioned and probably worth the 40k. I doubt the owner was trying to be completely concourse correct which is fine by me.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 10-16-2021, 11:51 AM
padgett's Avatar
padgett padgett is offline
Did only the Judge have the fake engine turned lower dash in 70. Remember an attempt at a repop in the last century that had too many swirls. Were many fake woodgrains in the '60s and '70s. Have a roll or two in the back garage but not sure what for.
Web Site
Old 10-16-2021, 02:38 PM
scott70's Avatar
Gto dash and judge had the same engine turning and wood grain.
Old 10-16-2021, 02:39 PM
DavesGTO's Avatar
DavesGTO DavesGTO is offline
All 70-72 GTO’s got the engine turned aluminum lower dash. Dash bezel wood grain looks correct, dash looks capped. Probably why the glove box door looks messed up. Added trunk release and rear lamp monitor. Fiber optic grommets look different than what I have seen from Baltimore built cars.
Old 10-20-2021, 03:37 PM
LKLusza's Avatar
LKLusza LKLusza is offline
I'm not sure the seats are correct. I thought that '70 seats had the seat back release button in the middle of the seat back. This one looks more like a '68 or '69?
Larry
Old 10-20-2021, 03:39 PM
DavesGTO's Avatar
Reclining passenger seat has the button on the side.
Old 10-20-2021, 06:19 PM
LKLusza's Avatar
That's really interesting. I was unaware that reclining seats were even an option. Thanks for sharing. That said, however, the vehicle in question also has the side button on the driver's seat too. Was there ever a reclining driver's seat option?
Larry
Old 10-20-2021, 06:21 PM
DavesGTO's Avatar
Not that I heard of, just power driver seat
Old 10-20-2021, 06:23 PM
DavesGTO's Avatar
No, only power driver seat optional
Old 10-21-2021, 12:26 AM
getmygoat's Avatar
$80k for a regular GTO. Crazy money. Seems like these cars were selling for $20k just a few years back.
Old 10-21-2021, 03:06 PM
When you ordered the reclining passenger seat option in 69 and up it resulted in both seats using the 68 spec side mounted seatback release buttons. Interestingly the hard shell seatback covers are actually not the same as the 68 seatbacks. They use the lower flange design like the 69-72 seatbacks rather than the 68 flange. This makes them specific to 69-72 recliner only, however they both interchange functionally and look the same unless you flop the seatback forward.
I wonder why the seat back button was moved in 69 anyway, I find the 68 button easier to see and use but I guess the 69+ rear center button for the passenger seat is reachable by the driver, chivalry wasn't dead yet!
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 10-21-2021, 04:12 PM
I do not think so. I am trying to remember where I have seen them different length (for resonance issues?).
Part numbers are different LH, RH yet no hanger brackets to make them handed, unless GM made the drain holes handed (doubtful). So IIRC one unit was a bit longer.
