1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 01-26-2019, 01:00 AM
Gear_grl83's Avatar
Gear_grl83 Gear_grl83 is offline
Default Just got an ‘85 TA FI Have a question
Picked it up yesterday on the cheap, knowing there was discrepancies, just working out the kinks.
The one that I’ve been struggling with a bit today is the air cleaner assembly. I’m not sure what the original looked like, I only seem to have to bottom, top is MIA, and trying to find the assembly has been like where’s Waldo.
So far what I’ve found seems to be a top with a big box on top of it (noise dampening?). However the only two I found said they’re for a Formula or GTA, is there a difference? Same on the TA? Also the one I have has 4 holes at the bottoms whereas the ones I found have one large hole, does it matter?
The box that’s between the intake duct and the MASS, is this also noise dampening? I found it had a hole sheared from the pulley on the alternator. Is this a thing?
Things are obviously off, I just don’t have a Chinese blueprint to know what it is. I’m working on getting manuals as well as the parts manual.
Or would I just be better off converting to the performance filter sys?
Thanks in advance!!
Thanks in advance!
