Old 06-01-2018, 02:11 PM
raggedjim raggedjim is offline
Default '73 Trans Am no a/c dash bird
I'm try to finish a dash insert for my car and have found conflicting information on whether the dash bird should be to the right side of the dash or closer to the volt meter. Pics on the internet can be found to support either one.
Thanks, Rg
Old 06-01-2018, 03:30 PM
bird72's Avatar
bird72 bird72 is offline
original 72 I had, unsure other years.
72 Bird
Old 06-01-2018, 03:35 PM
Thanks Anthony, I found other pictures of 1970-71 with the bird in the same location as yours but then I found some with it close to the volt meter.
Also found this thread http://forums.maxperformanceinc.com/...17#post4355117
I THINK the bird should be close to the volt meter on a 73-74.
Rg
Old 06-01-2018, 08:30 PM
73T/A 73T/A is offline
I just checked my non air 73T/A and the bird is indeed next to the voltmeter.
2001 Trans Am,WS6 Sunset Orange Metallic (sold)
1973 Trans Am 455,4speed
1970 GTO
Old 06-01-2018, 08:42 PM
SD73's Avatar
SD73 SD73 is offline
Here's a pic of my '73's for your reference..
Old 06-01-2018, 10:03 PM
Formulabruce's Avatar
Original , NON T/A , with Woodgrain, original 1973 NON A/C
Looks like the NON T/a was different than the T/A dash , with No Ac...
Name:	original dash 73.jpg
Old 06-01-2018, 11:06 PM
mlewisariz mlewisariz is offline
On my 70 T/A it's located to the far right.
1970 Trans Am RAIII 4/spd Blue/Blue Van Nuys built
1977 Can AM 400ci Sunroof car
1973 Grand Prix 400 A/T (Parting out)
Old 06-02-2018, 07:11 AM
The Boss's Avatar
The Boss The Boss is offline
The woodgrain was different every year too - unfortunately both of the 73 bezels I have are A/C ones so no birds.
And go racin' in the street.
Old 06-02-2018, 09:25 AM
bird72's Avatar
The Left Voltmeter alignment sure looks good. Symmetry with shifter. After I first posted I realized wood grain example could be wrong for TA. Now it seems we have the bouncing bird scenario
72 Bird
Old 06-02-2018, 10:40 AM
Held for Ransom's Avatar
Confirming. For the '73 TA (engine turned dash) the bird is above the cigar lighter (when A/C is not equipped), as pictured earlier.
So long, farewell.
Old 06-02-2018, 11:29 AM
I think I bought this particular bezel from you a long time ago.
Old 06-02-2018, 11:30 AM
John V. John V. is offline
My 4 spd '73 TA non-A/C, non-SD has the 'bird above the cigar lighter same as in the pic posted by SD73.
Old 06-02-2018, 11:36 AM
giles's Avatar
giles giles is offline
I believe that on the engine turned TA dash inserts, the bird is to the right on ‘70s only. ‘71 and up should be on the left. I don’t know about changeover from 70 to 71. I doubt there was a clean break at the model year and some late 70s May have had LH birds or early 71s May have had RH birds. I have some data on this. I’ll look and check back.
Old 06-02-2018, 12:48 PM
In addition to my 70 dash I have a 71 with bird to the rh side. It also has all black bezels which indicate it isn't very early production.
Old 06-03-2018, 02:11 PM
Norwood's Avatar
Norwood Norwood is offline
7c 70 my bird is a left
Old 06-04-2018, 02:46 PM
Well, I'm with you fellers, I'm going to put it on the left. I couldn't find a decent 73 aluminum dash so I welded up the holes in a later dash to make it favor the 73 dash (it still has the larger wiper opening, but as far as the rest it will be close).
I'll post a pic once I get it done.
Thanks for the replies.
Rg
Old 06-09-2018, 08:02 PM
JUDGE3 JUDGE3 is offline
left, right, mines a middle! I didn't like the big gap to either side. as we know holes were drilled and clipped on from the factory. I got a new bird and ground down the pins and put it on with silicone adhesive so as not to make my bezel permanently altered.
Old 06-10-2018, 11:00 AM
bird72's Avatar
/\ Pontiac shoulda thought "middle of the road"......
72 Bird
Old 06-11-2018, 04:44 PM
Nice job, is that a oem dash bezel or did you make it? It looks great.
Rg
Old 06-13-2018, 05:28 PM
Default Home cookin
Rg
Thanks, yes I made it. started with a no ac base firebird bezel, bored the 2 holes to trans am locations, then pain stakingly applied the engine turn decal. I epoxied metal in the blinker arrows to further clean it up and ordered the speedhut gauge with built in blinkers and highbeams.
