Old 12-19-2023, 10:03 PM
6d7gto 6d7gto is offline
Default Anyone know the casting numbers on GM part #5469245 wheel cylinders?
What is the casting number(s) located on original Delco Morraine brake wheel cylinders with the GM part #5469245? These are 7/8" diameter wheel cylinders for the rear brakes.
Thanks.
Old 12-19-2023, 10:45 PM
Scott Thelander's Avatar
Default wheel cylinders
cast number
I dont think so''
heres a few I had that came off 67-72 Abodys
ID:	625306   Click image for larger version
Old 12-21-2023, 02:24 PM
Originally Posted by Scott Thelander View Post
cast number
I dont think so''
Hi Scott! The sign in your photo says 5464 079. Is that the casting number or are you saying that the number is not actually cast onto the wheel cylinder?
Thanks.
P.S. Do you have any nice ones still for sale?
Old 12-21-2023, 05:23 PM
gto4ben gto4ben is offline
Here's are photos with the casting numbers.. Zoom in Scott's photo and you'll see them too.
ID:	625403   Click image for larger version
ID:	625404   Click image for larger version
Old 12-21-2023, 05:50 PM
sorry
cast into cylinder
i may have a single but no pairs ...
one gent bought them all for several cars he was restoring...
I may know where a pair are tho .... I will check ....
sorry
cast into cylinder
Old 12-21-2023, 05:56 PM
Ooooh....NICE!!! Is there an emoji for drooling?
Old 12-21-2023, 05:58 PM
sorry
cast into cylinder
Thanks. I appreciate it.
Old 12-22-2023, 11:54 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Here are the OEM front and rear brake wheel cylinders from my 1965 Survivor.
I sent out all 4 cylinders, plus the OEM Master cylinder for a sleeve and complete rebuild to keep this car Original.
Brakes work perfectly as new.
ID:	625445   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 12-22-2023, 11:20 PM
Excellent choice for your survivor. I plan to do the same. If/when I can locate good candidates, they will be sent to Jeff Karps here in Southern California. Heard nothing but praise for his work.
The Following User Says Thank You to 6d7gto For This Useful Post:
