Read my post #12, you did not mention piston volume so I did not add that in.
OK Last edited by 65sport; 08-20-2019 at 02:04 AM. |
Deck clearance is your stated .025, see your post #11. How many cc's are in that .025? Put some 6X-4's on if the valve reliefs are too many cc's. This isn't the f-ing race section where forum members put other member down! |
TC, 65 is thinking you are saying he will have 9.0 with his 66 heads. That is how I first read your post.
65, TC is saying you'll have 9.0 with 6X-4's. The English language can be rather ambiguous, causing such confusions.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
If I reach my target of 9:1 CR, how do you think my 455 will idle with the 214-224-112 LS ? |
If I reach my target of 9:1 CR, how do you think my 455 will idle with the 214-224-112 LS ?[/QUOTE]
I have, and have had that cam in a ton of engines. Slight, very slight lope at about 500- 600 rpm in 9:1 bigger cid engines. Above 700-800 has a smooth idle. I will mention this, since you mentioned having rebuilt 6x-4, and a good crane 278. That is a good combo in a 455. A 455 probably has a about equal vacuum comparing the 214/224 at upper 8:1 with the 66s as the 278 crane would with the 6x-4 (est 9.4:1 compression. That crane is an asymmetric profile, the 214/224 is symmetrical on the ramps. That crane is a well design modern cam. It would run all your vacuum accessories.. just an opinion if your doing the screw in studs, the 6x-4, crane 278, in a lower 9s 455 is a really nice combo. 214/224 would be better with the 66s imo in that 8-9 compression range. The 214/224 seems to like 9:1, I have not seen any reason to go beyond 9 with that cam in bigger engines. Pressed in studs bolt neck studs should be ok with the 66s and 214/224. 204/214 is a stock cam, smaller than some of the mild OEMs. If you want a stock cam, it is fine too. Last edited by Jay S; 08-20-2019 at 06:11 PM. Reason: Edit |
I have, and have had that cam in a ton of engines. Slight, very slight lope at about 500- 600 rpm in 9:1 bigger cid engines. Above 700-800 has a smooth idle. I will mention this, since you mentioned having rebuilt 6x-4, and a good crane 278. That is a good combo in a 455. A 455 probably has a about equal vacuum comparing the 214/224 at upper 8:1 with the 66s as the 278 crane would with the 6x-4 (est 9.4:1 compression. That crane is an asymmetric profile, the 214/224 is symmetrical on the ramps. That crane is a well design modern cam. It would run all your vacuum accessories.. just an opinion if your doing the screw in studs, the 6x-4, crane 278, in a lower 9s 455 is a really nice combo. 214/224 would be better with the 66s imo in that 8-9 compression range. The 214/224 seems to like 9:1, I have not seen any reason to go beyond 9 with that cam in bigger engines. Pressed in studs bolt neck studs should be ok with the 66s and 214/224. 204/214 is a stock cam, smaller than some of the mild OEMs. If you want a stock cam, it is fine too.[/QUOTE] X2, yes!!!
Thanks Jay !
Thanks 77 TRASHCAN !
I'm a little surprised that you wouldn't use your Crane 278 cam. It's 222/234 @ .050" is about the same size as the Crower 60916 that measures 221/229. I was going to install the Crower in my Bonneville project but ended up selling it to a club member for the 455 build in his '66 GTO. Idle was very mild and worked with the stock converter. His car has a very good mid-range punch. We kept compression at 9.1:1 with dished pistons and his #93 heads.
I had a Crane 214/222 HR cam (114 LSA) in my 8.6:1 low compression 400 engine in the Cruiser. Even with the 400 I always wished I went one size larger on the cam. With Dougs headers and a very decent exhaust it still sounded stock.
My engine is a recent rebuild in regards to how very little wear on it but I've never been able to talk to the last person that ran it. A guy stored it in my friend's garage and he decided to sell it. He didn't even know it was a 455, he thought it was a 350. I actually told him but he did not raise the price. My main concern is the rods. My machinist told me I could bring the rods with the pistons still on and he would recondition them and put on ARP bolts for $180. If I do that, I might be more willing to go with the Crane 278-2 cam. 222-234-114LS with .467-.494 lift. According to Crane this cam wants 9.5-10.75:1 CR so my 6X-4's would put me right there. OR I can break open the billfold, get 30 cc dish pistons use my ported 670's, buy some Eagle rods, get the thing balanced and not worry about RPM's. What I'm gleaning from these conversations is that the 455 engine tolerates a larger cam, something I'm not experienced with. So, thanks to you all for sharing the experience. |
[QUOTE=lust4speed;6053442]I'm a little surprised that you wouldn't use your Crane 278 cam.
I also have a new, unused Elgin E-1221-P. It's 224-234-114 and .466-.488 lift. Was given to me with an intake I bought, just needs new lifters. I like the Crane grind better it's a little less than the Elgin. |
Thunderstorm alarm woke my up. So I will guess i will get to go first, lol
Crane compression ratio ranges are good for a 350 cid engine. Very accurate actually for a 350 cid engine. But not for the bigger 455. For the same compression the compressed volume is more on the 455 than the 350 (350 is about 24% smaller). Look at it this way, there is more volume in the cylinder for the overlap area of the cam on the bigger engine, 455 has more air to be diluted by the intake and exhaust mixture. It takes more overlap to effect the 455. Most cam mfg ratings are based on 350 cid, unless they say otherwise. Elgin grind would be absorbed by the 455 too, also a small cam in a 455. Elgin is the same cam profile as the 204/214 and 214/224, just the next step up, exhuast profile on the 214/224 is the intake profile on the 224/234. We have never rebuilt a Pontiac that did not get arp rod bolts. Something that gets done here even on a stock build. Last edited by Jay S; 08-21-2019 at 04:41 AM. Reason: edit |
Folks with a motor of under 10 to 1 comp you would be giving up a good amount of much needed low lift Exh flow by bolting up a set of stock 6X heads without at least fitting them with 1.77" Exh valves with a 30 degree back cut.
Your giving up some 22 cfm of Exh flow at peak lift as compared to the 66 casting and between .050" lift, .100" lift and .150" lift your giving up a total of 15 cfm minimum! You don't need a duel pattern Cam to crutch up the flow ratio any more with the above rework if your keeping the Intake ports about stock.
I'll take the piston/rods out and have the bolts installed, rods honed. . |
Not accurate, but it is how the factory specs always overstated CR in the muscle car era.
#38
So true ! My engine 71 455-325 HP was supposed to have 8.2:1 stock compression, that's with the big head gasket, stock deck, approx. 6 cc valve reliefs. In reality that would be around 7.86:1.
#39
Update
Found a bare set of 6X-8's on craigslist for $40. Wasn't expecting much, but after all only $40 bucks. Magnafluxed-good Flatness-good Valve guides-tight I'm astonished at how good the condition is on these heads. I plan on taking the valves, retainers, push-rod guides and rocker arms off the #66 heads and using them. Just need to get some new springs, seals, 7/16" rocker studs and friction nuts. I used the used the valves from the #66 heads to check the fit in the 6X-8's and remarkably good. I got lucky. |
#40
Nice find no less nice price!
Machine work wise do not forget to have all the guides cut for .530" seals and then grind off the remains of the machine lip on the short turn of each Exh valve bowl then blend and polish out the bowl. Also grind off the casting nub on the crown of each Exh port short turn. Next gasket match each Exh port to a factory steel gasket on the top / roof only, and blend this in for 2 inches.
