Old 11-07-2023, 06:59 PM
nh68gto's Avatar
nh68gto nh68gto is offline
Question Heater control light
So what do you do if the prong thing that hold the black socket in the control housing is missing?
Anyone make it or something else to get socket to stay.
I think it’s used in two locations on a 69…?
Send it! It’s going home on a trailer.
Old 11-07-2023, 09:51 PM
OG68 OG68 is offline
If they're like mine, you may find it inside the controller.
2007 Cadillac SRX
Old 11-08-2023, 10:06 AM
exactly, same problem (and same piece) with clocks and dash tach.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 11-08-2023, 11:28 AM
And the rear arrowhead lights for 68.
69 Tempest / LeMans too?
The metal ring has tiny barbs that supposedly lock into the plastic socket. When replacing a bulb they sometimes pull out of the plastic creating a larger hole for the barb to lock Into.
I've thought whether filling the small holes with epoxy and then pressing the ring into the epoxy would help keep the metal ring in place.
I haven't seen the metal rings reproduced. I have seen same design NOS sockets on ebay for Olds and Buick from time to time. Don't know if they're the same size.
2007 Cadillac SRX
Old 11-08-2023, 05:30 PM
Scott Thelander's Avatar
x3
i have a couple spares if needed
Old 11-08-2023, 06:14 PM
My MO when running into this is to fish the missing thingie out of the clock or heater control etc. Ever so slightly bend the hooks so they bite better, inject a drop of crazy glue into each hole in the rubber, install a new bulb and reinstall it and never touch it again. We will hopefully die of old age before it needs replacing!
1969 Bonnie Cvt
Old 11-08-2023, 10:35 PM
Entropy11's Avatar
Entropy11 Entropy11 is offline
Just like North posted, I do the same. Bend the barbs out a little and toss a dab of some adhesive in there before pushing the barbs back in. I used PC-7 epoxy last time.
Doorman Help! #85805 worked perfect in my quarter panel side marker lights.
The Following User Says Thank You to Entropy11 For This Useful Post:
Old 11-09-2023, 09:04 AM
nh68gto's Avatar
I don’t even have the prong thing
Old 11-09-2023, 09:15 AM
nh68gto's Avatar
Old 11-10-2023, 05:22 PM
So you've confirmed that it's not in the unit?
In that case Entropy's post looks like a good bet.
Old 11-10-2023, 06:03 PM
I believe that inline also sells a clock harness that includes two sockets including the metal prongs.
1969 Bonnie Cvt
Old 11-11-2023, 03:13 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default Heater control night time lamp
Hi, is this the part your talking about?
Name:	68-69 GTO dash heater control lamp.jpg
ID:	623168   Click image for larger version
Name:	68-69 GTO dash heater control lamp_2.jpg
Peter Serio
Owner, Precision Pontiac
Old 11-11-2023, 03:48 PM
No, but that will work. The inline item I was referring to is a kit that has two of those fittings and the “Y” wire that connects the clock housing to the grey rheostat wire of the dash harness.
1969 Bonnie Cvt
Old 11-12-2023, 04:03 PM
nh68gto's Avatar
Peter, those are close to it.
The in line parts probably work too. Probably need to cut and re do wire connection.
