Old 01-30-2004, 11:55 AM
bjsgoat bjsgoat is offline
69 Tempest w/drums
I have spindles, mounts etc, etc but....the caliper mounting bracket to spindle bolts were missing on one side. When I called to order these bolts I was told they threaded into the spindle. The one set I took off went thru the dust shield, mounting bracket, spindle and had a nut on the back side. Are there 2 types or did I get a bad set? Mike
69 Tempest w/drums
Old 01-30-2004, 02:31 PM
engineer engineer is offline
depends, the bottom two are bolts with nuts on the back side to hold the tie rod bracket to the spindle, while the top is a bolt that threads into the spindle.
Old 01-30-2004, 06:18 PM
It must be the bottom 2. Fine thread with a good sized shoulder. Know where I can find these??
