Old 08-28-2008, 10:25 AM
mushie1965's Avatar
mushie1965 mushie1965 is offline
Default headlight switch
I hope that someone here will be kind and send me a pic of the pin configuration on the headlight switch of 1965 Bonneville
Larry
Old 08-28-2008, 05:35 PM
66bonne's Avatar
66bonne 66bonne is offline
I'll have a pix for you in a few minutes, have to root around in the parts bin.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 08-28-2008, 05:46 PM
66bonne's Avatar
Hope these help:
ID:	141357   Click image for larger version
Old 08-28-2008, 11:21 PM
mushie1965's Avatar
Default Thanks for the pics
Thank you for the pics,that is a 65 Bonneville switch? If it is I have had the wrong swich in my car for 23yrs Larry
Old 08-29-2008, 12:33 AM
66bonne's Avatar
Hmmmm --- I bought the switch a few years ago and was told that it was a NOS 65 big car head light switch. However, I haven't bothered to match it against another 65 switch, maybe I should. You have my curiosity up.
Jim
Old 08-29-2008, 01:36 AM
engineer engineer is offline
if your switch worked for 23 years, why are you asking? look at the connector and tell what switch pattern you need.
Old 08-29-2008, 01:52 PM
mushie1965's Avatar
Default Headlight switch
My switch has worked for 23 yrs.I replaced it just after I got the car,the dash lights would blink and I would have to "jiggle" and turn the knob and stem to get them working.I got a switch from a local auto supply . So now within the last 6 mos the dash lights have gone out,I tried the "wiggle' method it worked for a few weeks then finally gave out.In writing here I found out that there is only one switch that will work .I pulled the switch the other day and found the plastic on 2 connectors were burned and melted some and a different configuartion than other 65 GM big cars I checked ( a Buick 225,an Olds 98)my plug in not a solid plastic plug but has 3 seperate plastic connectors. I have totally confused my self on this issue my headlights work but no dashlights. None of the auto stores list this switch anymore Delco D 1462 as so I was told here..............................Larry
Old 08-29-2008, 05:56 PM
66bonne's Avatar
As with a lot of headlight switches each year,make/model tend to be unique unto themselves. Not always, but usually.
With those burnt connectors you either have a bad headlight switch or your dimmer switch could be going bad. Bad dimmer switches can cause the hadlight switch to overload. Been there, done that.
Go luck, Jim
Old 08-29-2008, 08:07 PM
Jeff Hamlin's Avatar
M65,
PM sent.
LMK if I can help.
Cheers
