Pay someone to do it properly. That means welded.
I think so too.....have a PRO do it!
FM Dan, Can you post some pics of the lower 1/4 panel PATCHES for him?? I used them on my 67GTO and they fit "like a glove".....The 67 GTO rocker moldings are EXCELLENT also! Eric
You guys are right and yea a pro should do it. I should say I have a 66 and I believe there are some differences in the panels behind the wheel. My car needs alot of work here you can see what I'm working with... Car is all put back together right now but I can stick my arm in the quarter panel and I really don't like that!
William (BJ) 1966 Pontiac GTO |
Now that I see the damage...I would seek another panel, and professional installation! A good bodyman can make that look like it never happened. Mine only had rust behind the wheel and down low, under the molding.....Eric
I have a friend that has been doing collision repair for 12 years look at this for me. He said he could make it disappear but his main concern is where do I want him to stop since he can't weld to rust and the trunk is rusted out as well along with the wheelwells...
I did take the car to a restoration shop and basically they quoted me $20k to get the car acid dipped, replace all the metal that needs replacing, and e-coat the whole car. No body or paint work here just metal replacement. At that point I didn't know what to do my car isn't worth that investment to me from a collectability stand point or for sentimental reasons. I kind of think they just didn't want to do the job honestly since it would take up so much time and space. What I need to do is find someone who is retired who likes to do this kind of work and just let them have the car to work on at their leisure with a loose time deadline and pay them cash by the hour, I think...
PY sells the trunk floor, and wheel wells...if you are doing lower 1/4s you should do the trunk and wheel wels at the same time!!! 20K without paint is a bit steep!
I meant dm fan, not Fm Dan....hey too many gasoline fumes! Eric
What you need is an experienced shop that does this kind of work regularly. You don't need a high end $50.00+ per hour shop that does concours resto's. You also don't want the corner body shop turned loose on it. This is where belonging to a club has benefits, ask around and find out where other guys in your area have had work done. For reference, replacing both quarter skins, outer wheelhouses, trunk extensions, trunk floor and braces and repairing the inner wheel houses as needed should take a competant experienced shop anywhere from 125 to 200 hrs, it depends on the extent af the damage. If you can find a reasonable shop/guy to perform the work at a fair rate around $30.00 per hour, the labor will run around 4500.00, parts will be 1500.00, figure in another 1,000.00 for primer, supplies, media blasting, etc, the total comes to 7,000.00. That is a realistic estimate to complete the metalwork and get everything in epoxy primer. Even if you have to pay 50.00 per hour, the total should not be much more than half of your 20,000.00 estimate. What area of the country are you in? Maybe guys on this board can direct you to a reasonable, competant shop in your area
Paul FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first. My site... needs updated- www.fastrestorations.com 68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs! |
I'm in Milwaukee Wisconsin area. I would have to say a $7k-10k range is much easier to stomach. Good advice thanks.
Funny you say 200 hours because that is the the amount of time my bodyman friend said it would probably take.
Gents, After watching my project near completion (body wise) 200 hrs. of hard work is putting it mildly!!!! I have a new respect for the "bodyman"...Talent/art/hard F 'ing work! Eric
Looking good Eric!
Got to ask so im i right in assuming quarters are now being made for the 67???
Not that I've seen yet...
Contact Joe Theisen at (920) 757-6763 and tell him Drew sent you.
'67 GTO Hardtop Montreaux Blue 400/400 '67 GTO Hardtop Regimental Red/Black Cordova top/400/4-speed '67 Bonneville Ragtop Montego Cream 400/400 |
Joe, got your PM thanks for the info! I will have to check that place out.
#38
I just don,t understand for all the inquires, all the web site Pontiac Companys can,t make these quarters happen??
#39
Dynacorn said it would be the biggest stamping they've ever made, something like 8 feet long, 3 feet tall, with a 9 inch draw. And they don't have original tooling to start with, it was damaged long ago.
Check out my cruise night! www.brewcitycruisenight.com |
#40
...30$/HOUR?
maybe in 1976. body shops here are 65-80$/hour. who, with ins, and a shop, and has a legit buisness works for 30/ hour? i'll be right there. |
