';69 - '70 Englne bracketry
Bracketry found at / removed from a 400 engine in a Catalina. Unsure of what exactly all it fits, as there were a lot of variations with the Pontiac bracketry. Am personally a Generalist, with a specialty in Chevrolet parts '69 up.
1. Power steering - aluminum bracket to head, with bolts (original) and stamped steel brackets to pump, and intake. Pump with single pulley,, no denting on pump housing. Personally, would clean and reseal pump, before use. VG original shape. $125 2. Aluminum AC bracket, believe went on passenger front, with two steel spacers. Found on ground, underneath the catalina. Appears identical to online brackets listing for up to $200 plus. $125, and will include two stamped steel brackets that are still with engine. Cast "H" shaped bracket that I believe is needed, for lower compressor mounting, is not present. $125 3. Original water neck, an online search defines it as '65 - '70 apps, this one is super clean and not eroded. $25. Everything above, for $225 plus shipping. Last edited by newmexguy; 02-06-2022 at 01:11 PM. |
