Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Old 10-09-2003, 02:29 PM
noob_goat noob_goat is offline
A quick search of prior posts turned up mostly positive results. Anyone had work done by him?
Any other recommendations in the Dallas area?
http://www.kimbarrracingengines.com/index.html
Old 10-16-2003, 08:06 PM
UnchainedGTO's Avatar
UnchainedGTO UnchainedGTO is offline
I have a buddy with a 69 GTO who used them. The motor was a bit tight on the clearances, but runs OK. Nothing special.
If you are not in a big hurry I recommend Cain's Performance in Plano. 972-578-1212. Give Michael Cain a call and see what he can do for you. He is not fast, but very good and is a straight shooter.
Thank you,
Don
1963 Lemans
1965 Catalina 2+2
1968 GTO
1969 Lemans OHC6
1972 Formula
1974 GTO
1986 Grand Prix 2+2
1986 Fiero SE
2005 Bonneville GXP
Old 10-17-2003, 06:59 PM
thirdgen455's Avatar
thirdgen455 thirdgen455 is offline
I think they built a buddy of mines dads 455, I don't remember if they fixed the screwups or if they did the screwups. BUT I know they have built some bada$$ motors. same goes for Rehr and Morrison, but when a friend of mine took his pontiac to R&M years agot they told him that they could not internaly balance his 455! he was like WHAT it was from the factory, why can't you. he told him holding the balncer and flywheel in his had "OH I thought it was extrnaly balanced". SO he left thinking these are the guys that BUILD prostock motors.
anyway e-mail Slow77ta and ask him about Barr
jhodges5747@sbcglobal.net he knows Shane (guy who's dad runs the barr motor) better than I do.
Old 10-18-2003, 02:04 PM
Banditone Banditone is offline
THIRDGEN. Sounds familiar years ago I Had a HOT CAM PUT in my 77 SE T/A 400 by a local SPEEDSHOP -- And I wanted them to properly tune it--they said they could'nt ? just before that the mechanic took it out and I Was with him--he was surprised --the way the car hauled a## .
Old 10-19-2003, 09:55 AM
By the way they had mostly chevy's parked in the yard--vette's etc. The mechanic recommended another speed shop to tune my car--never heard of a shop doing a JOB HALF WAY.
Old 10-19-2003, 06:55 PM
Held for Ransom's Avatar
Thirdgen455, Pontiac engines from the factory were externally balanced. Look at a flywheel or flexplate and you will see. That is why you can't just stick a Hayes flywheel on unless the engine was internally balanced.
So long, farewell.
Old 10-19-2003, 07:32 PM
what in the hell are you talking about? a extrnaly balanced motor will have a notch out of the balancer like a 400 SBC or 454 BBC and a counter weight on the flywheel. never in my life have I seen a pontiac with a notch on the balancer.
shesh
Old 10-19-2003, 07:48 PM
Maybe I should have said "imbalance". Hopefully this will explain it better than I. http://forums.performanceyears.com/g...1&r=9456023911
So long, farewell.
Old 10-19-2003, 08:01 PM
yes 0 balanced would mean what I said internaly balnced, the internals are blanced so the flywheel and balncer have to be at a neutral balance. if you have to grind it to make it 0 balance yes, but anyone could look at a stock balancer and tell it is a internaly balanced motor
Smilies are Off
