Old 04-25-2006, 04:27 PM
Mook Mook is offline
Default Water pump
Where can I get a water pump with the cast impeller, and what is the part number? Or how can I tell a water pump is cast?
Old 04-25-2006, 05:29 PM
george kujanski's Avatar
The cast impeller does NOT look like an alternator fan. A stamped impeller looks like an alternator fan.
George
Old 04-25-2006, 07:25 PM
As always thanks George!
Old 04-25-2006, 08:08 PM
CanAm1977's Avatar
CanAm1977 CanAm1977 is offline
The first picture shows an original factory cast impeller
Second shows a stamped impeller
Third shows the old factory impeller on left and a replacement
cast impeller on the right.
The fourth is the look on your face if you screwed up the reinstall of the
pump
You may have to check a few sources before you'll someone
that installs cast impellers on thier new or rebuilt pumps.
If your seperator plates are in good shape you could reuse but I'd replace.
Replacements are now available on Ebay that are made of stainless for longevity. After all it could be another 30 to 40 years before that water pump will ever come off your motor.
ID:	51116   Click image for larger version
ID:	51117   Click image for larger version
ID:	51118   Click image for larger version
Old 04-25-2006, 09:08 PM
Thanks.....that is tooo damn funny!
