Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 11-07-2019, 07:12 PM
Adecco Adecco is offline
Default 62 389 SD motor
True 62 389 SD motor some consider this more rare than the 421 SD , it has the same Isky cast iron cam and cast iron lifters Beswick ran in his funny car/and in 62, 4 bolt main, heads are ported/gasket matched for intake, correct Carter carbs, cast iron lost branch manifolds, this is a rare piece $25k. 708-834-8733.. Tom
ID:	523902   Click image for larger version
ID:	523903   Click image for larger version
Old 11-07-2019, 07:16 PM
ARP rods bolts, line bored, balanced, I will include the original cast iron SD bellhousing, SD flywheel cut and balanced for that price
Old 11-07-2019, 07:18 PM
Pistons are SRP forged, clevitt bearings,
Old 11-07-2019, 07:48 PM
tom s tom s is offline
I have to ask,other than a SD block and the exhaust manifolds I dont see another SD part?Intake is not,heads are not,no dist,no balancer,carbs are not?Tom
Old 11-07-2019, 07:49 PM
Also not SD valve covers?Tom
Old 11-07-2019, 07:55 PM
Default SD
Has the SD crank, pullies, water pump, yes it may just be a SD block in your eyes and your opinion in greatly appreciated
Old 11-07-2019, 07:57 PM
SD harmonic balancer, distributor is out but available,
Old 11-08-2019, 10:04 AM
FYI for an additional 59k I will include a pair of Mickey Thompson Hemi heads yes they are all intact and original
