vacuum leak
WHAT IS THE BEST METHOD TO CHECK FOR A VACUUM LEAK ON A 66 TRIPOWER. I NEED TO CHECK MANIFOLD AREAS . I THINKING CARBS ARE OK . I HAVE 15 AT CARB AND 7.5 AT MANIFOLD. THANKS
If you have a portable propane bottle you can turn it on to see if, when waved around areas that should be sealed, it makes the idle increase. If the idle does increase, that is where your leak is.
1967 GTO Tyrol Blue/Blk Cordova 400, TKO-600, 8.2 Posi w/3.55 400 + .020, decked to .005 SD Performance 240+CFM 670 heads RARE HO/RA manifolds RARE 2.5" Exhaust (18" Magnaflows) SD "Stump Puller" HR cam (230/236, 112LSA, 107.5 ICL) PRW stainless 1.52 roller rockers Forged TRW slugs SCAT H-Beam forged rods |
