Old 02-03-2024, 02:03 PM
BILL BOWMAN1's Avatar
Default Stubborn lower ball joint
65 Cat lower ball joint will not separate! I put a bunch of heat on it, pickle fork, smacking knuckle with BAH and nothing.
About ready to whiz wheel it off, then I can weld a nut on the stub and work it out. Any ideas ?
Old 02-03-2024, 02:14 PM
694.1 694.1 is offline
Maybe it's time to do the A are bushings too?
Still have my 1st Firebird
7th Firebird
57 Starchief
The Following User Says Thank You to 694.1 For This Useful Post:
Old 02-03-2024, 02:20 PM
Yes that’s why it’s coming apart.
Old 02-03-2024, 02:43 PM
77 TRASHCAN's Avatar
There's quite a bit of metal surrounding the ball joint shaft.
I rebuilt a 71 C10 front end over Christmas time.
I used a propane torch with MAP gas. Had to heat up spindle for 5 minutes or more, seemed like a long time. It finally let go...try the torch again...
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
Old 02-03-2024, 02:45 PM
misterp266's Avatar
Do you have a jack under the control arm? If not, the spring is pushing the ball joint into the knuckle. You may not even realize it’s free until you jack it up. I’ve never had one that wouldn’t break free with a sharp whack to the knuckle.
" Darksiders Rule "
The Following 3 Users Say Thank You to misterp266 For This Useful Post:
Old 02-03-2024, 03:15 PM
UGH!! Exactly why I ask you guys! Got it thanks!
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post:
Old 02-04-2024, 09:12 PM
LOL!
Happy Ending.
7th Firebird
57 Starchief
