I would think plastic media blasting would do the trick, it works on fiberglass and eveything else without harming glass, moldings, etc.
Brake Cleaner on a rag will remove paint easily. Stop rubbing when you get enough of it off.
It was just recently suggested to me to use SuperClean, in a bucket/trashcan, dilueted with water, to safely strip old interior dye off panels. Check this thread:
http://forums.maxperformanceinc.com/...d.php?t=697547 .
Spray paint will wipe off if you put lacquer thinner on a rag and rub it.
William (BJ) 1966 Pontiac GTO |
If it doesn't come off with lacquer thinner, it is safe to spray dye over the top of it. |
