Old 05-25-2020, 05:25 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by slowbird View Post
it's a proven fact that alum needs 2pts more compression here is a very good article comparing alum vs iron. /[/url]
Fake News! Internet banter for those that can't do.
Go fast, see Elvis!
  #62
Gach's Avatar
Gach Gach is offline
( quote from article: we are not going to be so cocky and say we Wouldn’t have made more horsepower with more compression with aluminum heads )
That’s because they would have. Thats kind of the point with running aluminum heads. They’ll tolerate more compassion than an ion head.
But to each his own, its all In having right combination with CAM being key.
You are correct Marcella did‘nt do the build, Chirs U ( sp ) did but it was Marcella top end ( his old Pro Port heads ) made 995 hp. on pump gas.
My advise to anyone with no experience ( first time ) pushing The compression envelope it’s a consult with the experts. Because picking the right cam is key.
Old 05-25-2020, 05:26 PM
PAUL K's Avatar
Hi Gach
Go fast, see Elvis!
  #64
Old 05-25-2020, 06:54 PM
Dragncar Dragncar is offline
Marcella didn't build that!
You know exactly what I meant. Find any small so called nothing burger to call me "wrong".
Marcella did the heads and intake, you know, the most important power making things in a engine. The ones that take the most expertise in doing correctly. Those and the cam are the heart of a engine.
Marcella, S Brown and Chris U, the usual suspects all doing their thing.
  #65
Old 05-25-2020, 06:59 PM
"can't do".......
Lets see if that's you.
Weight
ET
MPH and owner driver on those 1000HP E heads please.
Aw lets just not. I know where you stand and you know where I stand and lets not mess up the Street Section like the Race Section.
Have a nice day!
  #66
Old 05-25-2020, 07:02 PM
Originally Posted by NeighborsComplaint View Post
Thanks. I'll give him a call and discuss . Thanks.
Might want to E mail him first. He can be very hard to get ahold of on the phone sometimes.
Just do it, you will learn a lot.
  #67
Old 05-25-2020, 07:36 PM
Gach's Avatar
Hi Gach
Hi Paul.
Old 05-25-2020, 07:44 PM
PAUL K's Avatar
Originally Posted by Dragncar View Post
"can't do".......
Weight
ET
Have a nice day!
1/4X20TAPSTTFMF!!!
Go fast, see Elvis!
  #69
Old 05-25-2020, 08:33 PM
Gach's Avatar
EHTTF’MF. Thats all.
Old 05-25-2020, 09:03 PM
slowbird's Avatar
slowbird slowbird is offline
And Scott Brown had nothing to do with it. Keep trying, you'll get something right eventually
  #71
Old 05-25-2020, 09:14 PM
PAUL K's Avatar
^^^TRUTH^^^
Go fast, see Elvis!
  #72
Old 05-25-2020, 09:18 PM
Gach's Avatar
The build was over a year ago, even I couldn’t remember all the details, I had to go look. In that thread I give Chirs my opinion on cam, what I thought Pontiac’s like. Turns out I was wrong go figure. Chris made cam choice change. Thought I was helping. Marcella had his input ( I think on LS ) lube swap. Can you imagine making 1000 hp...actually 995 hp. Well close enough on pump gas with E-Heads.
DRAGNCAR ...I never like that guy...LOL wink.
Old 05-26-2020, 12:07 AM
blueghoast's Avatar
Why push the compression that little bit? How much power you guys think is there going from high 10:1 to mid 11:1? Is it worth the potential issues? Is the cam a good fit or is it a compromise on the higher compression engines so they don't ping?
Fwiw i was 10.8 on my pump gas engine and made just shy of 900hp, and i wouldn't want to push it any more than that nased on my experience.
What CI motor did you do you have?
  #74
Old 05-26-2020, 01:15 AM
Stan Weiss's Avatar
Was that a 554 ci, 11.8:1 CR engine that make peak HP around 7500 RPM?
Stan
Pontiac Pump Gas List
  #75
Old 05-26-2020, 05:46 AM
slowbird's Avatar
496
  #76
Old 05-27-2020, 11:38 PM
1/4X20TAPSTTFMF!!!
And STILL the man does not give any info. The man wants to make claims without backing it up. I thought that was a unwritten rule .
Prove it poser.
  #77
Old 05-27-2020, 11:42 PM
"nased on my experience" I believe you when you say that. Could not hang past that.
You know that cam I am selling came off of a 12.5-1 engine that did not detonate on 93 octane right ? Rod bearings looked new I am told.
  #78
Old 05-28-2020, 07:38 AM
slowbird's Avatar
Good to hear that cam worked. Post a dyno sheet from it or an et slip or pics of the nice rod bearings.
Why push it to 12.5:1? Did it make more power or run better than my 10.8?
  #79
Old 05-28-2020, 07:43 AM
PAUL K's Avatar
Prove it poser.
Troy is "in the know" he ran 10.8 once (and windowed his block) we are fortunate he shares his wisdom with us... He is the real deal. He is so good his brand new cam he is selling didn't detonate in a 12.5:1 compression engine that evidently never ran!
Go fast, see Elvis!
  #80
Old 05-28-2020, 08:21 AM
slowbird's Avatar
For the record, yes more than 11:1 can be ran on pump gas but just because something can be done doesn't mean it should be done.
