Old 11-20-2016, 08:27 AM
455hota's Avatar
455hota 455hota is offline
Default Best Source for Wiring Harnesses??
From everyone's experiences and opinions, where is the best source to buy reproduction wiring harnesses?
I have used M&H as well as Lectric Limited both in the past. I have also used Ames, Year One, and Performance Years.
Maybe it does not matter, but I just thought I would ask for some opinions.
Thanks in advance.
...Steve T.
"Resurrection of a 1970 Trans Am" Blog
www.455hota.wordpress.com
1966 GTO 4 speed Hardtop Alabama car (Marina Turquoise w turquoise interior)
1970 TA 4 speed Canadian car (Lucerne Blue w bright blue interior)
Old 11-20-2016, 02:49 PM
blue71ta's Avatar
blue71ta blue71ta is offline
M&H gets my vote. I have used them in 3 of my cars and will buy from them again. Nice quality.
Old 11-20-2016, 03:02 PM
Norwood's Avatar
Norwood Norwood is offline
Good experience with both Lectric Limeted and M&H. You list Ames and Year One but they are not actual manufacturers.
Old 11-20-2016, 03:10 PM
Bentwheelbob's Avatar
Agree with Norwood. Both M&H and Lectric are equally good. Problem with M&H is they "batch" build harnesses and if the harness you want isn't in stock it could be 6 or 8 weeks until they build another batch. Lectric Unlimited will usually construct a harness within a week or two if not in stock. Ames buys from M&H I believe.
Whichever supplier you use you should assume the harness will not be in stock and should order it well in advance of when it will be needed.
Old 11-20-2016, 03:36 PM
lugnutx2 lugnutx2 is offline
I used Lectric limited on my 65 vette and the harnesses were spot on! I just bought forward lamp and engine harnesses for my GTO from another supplier and they don't want to stay snapped to the original main harness at the firewall junction. Maybe my original harness connector has issues? I haven't looked into to it very far yet.
Old 11-20-2016, 04:52 PM
455hota's Avatar
Great feedback guys! I will narrow down to M&H or Lectrc Limited
...Steve T.
Old 11-20-2016, 06:25 PM
FunctionalShaker FunctionalShaker is offline
American Autowire is another one. Colorado's Wellington Classics will give you the best price. I don't think any of them will exact match originals. Which harness(s) are you looking at replacing?
The Following User Says Thank You to FunctionalShaker For This Useful Post:
Old 11-20-2016, 07:18 PM
American Autowire Factory Fit harnesses is what have been using. Excellent product. Plan on ordering a few dash harnesses late this Winter.
American Autowire absorbed J Parker Wireworks early this century, mention that for those that have used exact restoration harnesses from this company before.
Old 11-20-2016, 09:53 PM
I 've found the fuse blocks to be incorrect, clips to be the wrong colors and no courtesy sockets installed (70). The sockets they have are also the later style.
Old 11-21-2016, 12:54 AM
giles's Avatar
giles giles is offline
I've used M&H and have had very good experience. Their stuff is typically identical to a Packard OE harness, except for their own part number tag.
Old 11-21-2016, 01:03 AM
I think M&H uses the same parts suppliers as A.A. and when I asked them to send me a pic of the fuse block, they said they wouldn't have one until a harness order was placed.
Old 11-21-2016, 03:13 AM
Transamric's Avatar
A vote here for M&H also.
(Really, I just wanted to see that post count hit 2000!)
Old 03-04-2024, 02:38 PM
VCho455's Avatar
VCho455 VCho455 is offline
It's been over 7 years since this was active does anyone have new information?
Needing a new harness for my 72 Firebird. Going to be V8 with factory guages, late model alternator, HEI distributor, no AC, 4 speed.
Old 03-10-2024, 09:35 PM
kencar62's Avatar
kencar62 kencar62 is offline
I used M&H for the majority of the harnesses on my '73 Bird with a couple of American Autowire accessory type harnesses.
Old 03-11-2024, 08:05 PM
triathlonx13's Avatar
American Autowire
Old 03-11-2024, 09:40 PM
Ramairnacho Ramairnacho is offline
Default fuse boxes
can anyone share pics of there new wiring harness fuse box
Old 03-12-2024, 12:29 AM
jhein's Avatar
jhein jhein is offline
I did an new American Autowire dash and engine harness last year. I'll try to get a pic of the fuse block tomorrow.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
The Following User Says Thank You to jhein For This Useful Post:
Old 03-12-2024, 08:10 AM
TAKerry TAKerry is offline
2023-11-22_10-00-43 by Kerry Grubb, on Flickr
2023-11-22_10-00-55 by Kerry Grubb, on Flickr
I got this from Summit. Its a bit later car (79) but everything was there and worked great. I only swapped the engine compartment as it had been hacked up pretty good, the front light harness was fine so I kept it. Kind of a shame as the new one was so nice, but for the cost I will clean up what is original.
The Following User Says Thank You to TAKerry For This Useful Post:
Old 03-12-2024, 10:19 AM
napster's Avatar
napster napster is offline
American Autowire was used to rewire my '73 T/A.
Old 03-12-2024, 12:17 PM
jhein's Avatar
