Old 08-23-2023, 04:27 PM
NO67GTO's Avatar
NO67GTO NO67GTO is offline
Default Remote mirror control placement.
Hey everyone wondering if y'all could help. My 69 Firebird with std interior is supposed to have a remote mirror from the factory according to the PHS.
It had a std mirror when I bought it and want to install the remote.
I took the door panel off hoping to find a perforation in the cardboard but no luck.
I scoured the internet but haven't found much for a 69 with remote mirror.
Anyone have any pics where the remote end mounts in the door panel maybe some measurements?
Thanks all. Anxiously awaiting your response
Sent from my Pixel 6 using Tapatalk
Giving To Others!!!
V.P. Pioneer Valley GTO Association
www.pvgto.com
67 Lemans 455 best et. 12.023@ 111 mph LVD 9/2008
68 GTO H.O. in progress?
Old 08-23-2023, 05:44 PM
NO67GTO's Avatar
I just searched the forums and found some old posts. I may just leave the std mirror for now. Wait and go to some local Pontiac shows . But if any of you have a 69 remote mirror std. Int. bird please send pics of outside and controller on door panel
Giving To Others!!!
www.pvgto.com
Old 08-23-2023, 06:01 PM
Cammer-6 Cammer-6 is offline
I have a 69 remote mirror in pretty good shape
PM me if interested
I may also have a door panel thats got the hole.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 08-23-2023, 06:07 PM
NO67GTO's Avatar
PM me if interested
Pm sent
Giving To Others!!!
www.pvgto.com
Old 08-23-2023, 06:47 PM
pics of mirror
Found a pic of door panel with hole for mirror control...
It is the custom trim molded panel not the standard trim flat panel.
ID:	618709   Click image for larger version
Old 08-25-2023, 12:27 PM
I could have missed it but looking thru the 69 Assembly manual it has nothing.
In the index it lists remote mirror but page # is missing.
Looking thru the body section comes up with nothing.
Old 08-25-2023, 06:56 PM
Pete67FB400 Pete67FB400 is offline
I looked through my saved pics of remote mirrors and found these 3 shots labeled as being of a '69 remote mirror controller. I don't remember where the pics came from.
ID:	618800   Click image for larger version
ID:	618801   Click image for larger version
Old 08-25-2023, 08:26 PM
thats the custom trim option door panel
which is the same as one I have
Hes looking for the standard door panel.
Old 08-25-2023, 09:30 PM
heres the backside pic of the custom trim molded door panel
showing the hole for mirror control
Old 09-07-2023, 02:48 PM
I have a 69 ragtop with factory installed remote mirror and standard interior. This is the only pic I have but I'll take a close up one and post it later. You will need the upper bright metal mouldings as remote mirror cars with standard interiors use a 2 piece version of this molding.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 09-07-2023, 07:26 PM
you beat me to it North.
I forgot that one of my Cammers has standard interior and a remote mirror
but its in storage.
Old 09-07-2023, 07:59 PM
NO67GTO's Avatar
I have some pictures now I need to find one. GTO Mirrors have a different controller than the firebird
Giving To Others!!!
www.pvgto.com
Old 09-12-2023, 05:57 PM
Sorry for the delay, slipped my mind.
And sorry for the #*#* upside down iPhone pic.
1969 Bonnie Cvt
Old 09-12-2023, 09:03 PM
tekheavy's Avatar
tekheavy tekheavy is offline
Flipped it for ya.
Old 09-12-2023, 09:23 PM
Thanks!
Btw, this arrangement must have annoyed dealers somewhat. The dealer installation of a remote mirror option was probably the most common one they did in those years. It was cheap and easy to install, and it was easy for a customer to appreciate the benefit of not having to turn down the window every time you needed to adjust the mirror or if it moved when you slam the door etc.
But, when you look at this arrangement, you can see how this was it much less viable situation. Now, instead of just ordering the little box with the mirror and the appropriate gaskets and fasteners, he would have to order the two moldings that run across the top of the door to replace the single one that was installed on a non-remote application. Apart from this additional cost, I suspect that even the holes on the door panel that receive the upper molding would need holes in different locations for the retention pins that are folded over to hold the molding in place.
1969 Bonnie Cvt
