Old 03-01-2018, 07:29 PM
Norwood's Avatar
Norwood Norwood is offline
I think just one. The head ground strap on my car is screwed directly to the firewall
Old 03-01-2018, 08:17 PM
weranc55's Avatar
weranc55 weranc55 is offline
Cool. When are you going to have them ready? LOL
Old 03-01-2018, 08:37 PM
njsteve's Avatar
njsteve njsteve is offline
I think it's just one for the ground strap so it can be pulled out and allows the shaker to be pulled off the car. I don't recall ever seeing that do-hicky thing used for another application.
Old 03-01-2018, 08:38 PM
Held for Ransom's Avatar
Here is the engine ground strap and terminal from a '74 Firebird.
Like Norwood was saying, there's probably a few in the salvage yards.
So long, farewell.
Old 03-01-2018, 08:42 PM
njsteve's Avatar
Is that the regular firewall to block ground? It cant be the shaker ground since they didn't have working shakers. Our '75 has the ground strap but with a standard eyelet terminal on both ends.
Old 03-01-2018, 08:48 PM
Yes, '73 and '74 had the same set up. You're right on the '75 going back to eyelets on both ends. Maybe not that many in the yards as I had once thought.
So long, farewell.
Old 03-01-2018, 09:07 PM
Red Goat's Avatar
Red Goat Red Goat is offline
The '73 assembly manual shows this 2-piece style engine to firewall ground. When I took my 73 apart, it had the 2-piece ground. I sent it out with the rest of my plating.
Old 03-02-2018, 08:02 AM
njsteve's Avatar
So, does anyone have one they can spare? Or run across an aftermarket connector that will work. The blade on the strap seems to be larger than the standard size.
Old 03-02-2018, 09:29 AM
Norwood's Avatar
Not special just the standard .25
Old 03-02-2018, 05:04 PM
RamAirPwr RamAirPwr is offline
A few additional pics for reference
Name:	030808 032 (3).jpg
ID:	477014   Click image for larger version
ID:	477015   Click image for larger version
ID:	477016   Click image for larger version
1970 RAIII white/blue
Old 03-02-2018, 07:54 PM
weranc55's Avatar
Craig you could easily get 10 bucks a pop for those. I even know somebody that would order ten of them.
Old 03-02-2018, 08:59 PM
Norwood's Avatar
Maybe FormulaBruce’s guy NOT A TA can make them.
Old 03-05-2018, 03:19 PM
TA455HO's Avatar
TA455HO TA455HO is offline
I know they used to service these since I had some NOS. Down to just one for my car, but you can tell this has never been installed (no marks from a screw head)
The "springy" portion that is bent up from the bottom often snaps after several removals of the ground strap if you don't relieve the pressure of the clip before pulling.
Chad
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
Old 03-05-2018, 05:42 PM
tsmith455 tsmith455 is offline
2 per car. One for the shaker and one for the strap to the back of the head.
TS
Old 03-05-2018, 05:48 PM
Judge273's Avatar
Judge273 Judge273 is online now
Functional shaker had ground strap know. Other shakers too?
Mike/Illinois
Old 03-05-2018, 05:55 PM
njsteve's Avatar
My 73 SD does not have a shaker ground. Just block to firewall ground.
Old 06-20-2018, 11:38 AM
weranc55's Avatar
Just a update. Lectric limited sells both the ground straps. 15949 for the engine to firewall and 90536 for the shaker. Now we just need to find the female clips that go on the firewall
  #38
Old 08-22-2021, 11:05 PM
JAL71TA JAL71TA is offline
I realize this is an old thread but I belive I am having ground issues with my 71 455TA. Can anyone tell me where all the ground straps are attached? I see one that is attached to the shaker scoop, cannot see any other strap.
When the car is on and I turn the headlights and ac on my factory voltage gauge drops from 13/14 to 10/11. Car has the "slow" crank issue.
  #39
Old 02-21-2022, 05:31 PM
hiyabradHO hiyabradHO is offline
I am looking for two ground strap clips. Does anyone have any for sale?
  #40
Old 02-21-2022, 06:02 PM
Can someone tell me the correct screw that attaches to the shaker and the firewall? Do you have extras for sale? Thanks
