Old 02-17-2022, 03:12 PM
GTOGEORGE's Avatar
Default 1967 400 lifters
Is there any difference between a 67 400 block and a 76 400 block when it comes to lifters.
Im have a heck of a time keeping the lifters adjusted.
GTO George
Old 02-17-2022, 03:54 PM
No difference.
Old 02-17-2022, 04:00 PM
GTOGEORGE's Avatar
No difference.
I didn’t think so!
I am having a heck of a time keeping them adjusted.....they get tight and they get loose....weird!
Thanks,
GTO George
Old 02-17-2022, 04:53 PM
PAUL K's Avatar
PAUL K PAUL K is online now
Are you using poly locks? Or?
Go fast, see Elvis!
The Following 2 Users Say Thank You to PAUL K For This Useful Post:
Old 02-17-2022, 04:54 PM
GTOGEORGE's Avatar
Yes and also it’s not a 400 it’s a 421…….I’m bad!
GTO George
Old 02-17-2022, 05:02 PM
421 heads? Press in studs could be backing out.
Polylocks need the top of the stud ground flat for the set screws to seat on and stay tight, another possibility.
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 02-17-2022, 05:07 PM
PAUL K's Avatar
What Bart said..... Are they initially setting and then loosening up?
Go fast, see Elvis!
Old 02-17-2022, 05:44 PM
GTOGEORGE's Avatar
Same heads that were on my wife's 400 engine, I think they are 6x. They are screw in studs, I replaced the studs with 7/16" and got roller stamp steel rockers but im have a heck of a time getting these things to stay adjusted.
GTO George
Old 02-17-2022, 05:46 PM
No 421 block in 1967, so is it the heads that are 421?
The pushrods the correct length?
Old 02-17-2022, 05:49 PM
GTOGEORGE's Avatar
421 engine, 6x heads sam pushrods and lifters that was in the 76 400 engine, I just switch everything over. Then i bought the upgraded studs and rockers.
GTO George
Old 02-17-2022, 05:56 PM
Cam lobes going flat?
Those rockers are known for the rocker balls not being a good fit, possibly wearing in at this point. Watch out for bluing in the ball pivot area.
The Following 4 Users Say Thank You to b-man For This Useful Post:
Old 02-17-2022, 06:09 PM
77 TRASHCAN's Avatar
GTO George
My concern would be those rockers....
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
Old 02-17-2022, 06:44 PM
GTOGEORGE's Avatar
This are the ones I bought (they are new), I thought they would be better then stock rockers.
GTO George
Old 02-17-2022, 06:56 PM
Stock rockers or full roller rockers.
Anything in between reality isn’t worth using.
At least go for some proven Harland Sharp rockers, those roller tip stamped type rockers are sketchy at best in my opinion. Some folks have good luck with them, others not so lucky.
Old 02-17-2022, 07:04 PM
GTOGEORGE's Avatar
I didn’t know that thanks.
GTO George
Old 02-17-2022, 07:16 PM
I think it would be wise to pull those off and put the stockers back on before those rollers tips put any more metal in your engine.
I’d try to return them as defective because they likely are.
Old 02-17-2022, 07:17 PM
GTOGEORGE's Avatar
They are not only getting loose (ticking) they also get tight (where it starts to miss). And then I have to readjust them and it’s fine for a little while. Freaking weird!
GTO George
Old 02-17-2022, 07:19 PM
GTOGEORGE's Avatar
I don’t think they are wearing, I haven’t noticed anything strange an besides it really dyhave any miles on them! Maybe 50.
GTO George
Old 02-17-2022, 07:21 PM
punkin punkin is offline
Sorry if this was already answered but, has it been confirmed that the nuts are coming loose or something moving? Might try a little loctite blue and run the test again.
1968 Firebird
IAIIa 522
340 E-heads
Northwind with XFlow TBI
4L80E
3.50:1 Rear
Old 02-17-2022, 07:25 PM
GTOGEORGE's Avatar
Nuts are locking and they are not getting loose.
GTO George
