Old 01-16-2020, 05:16 PM
Entropy11's Avatar
Entropy11 Entropy11 is offline
Default Timing cover recommendations?
Sorry- been through all the posts I could find using search and couldn’t find info on brands.
Long story short, doing a water pump install last night (‘72 400) and saw the timing cover looking very corroded and grungy. Poked around a little to see how bad it was and could easily put a screwdriver right through the cover.
I need a new cover and my options appear to be:
Allstar Performance ALL90019
JEGS 50318
Summit SUM-G630
Pioneer 500455
They’re listed Above in decreasing price starting at $165 and ending at $100. Reviews on sites are all over the place so really nothing to go off there. I already have a new ss divider plate, gaskets, tube seals, and new ss tubes if I need those too so the extra parts included with some of the covers don’t mean that much to me. Just curious if anyone has any input on any brand in particular.
Also, how about harmonic balancers? Nothing crazy going on with this engine HP wise so am I ok with a new $50 one or should I go for something better? I went with the Flowkooler WP through Butler for the pump.
Thank you for any input/insight.
Old 01-16-2020, 05:54 PM
thepontiacman's Avatar
Why not get a factory timing cover in good condition.
Sent from my XT1650 using Tapatalk
Old 01-16-2020, 06:34 PM
DevoBuzz's Avatar
DevoBuzz DevoBuzz is offline
PowerBond balancers are decent for the price from what I heard.
1972 LeMans
461 stroker 10.3:1
Edelbrock D ports Scorpion 1.5 rockers
Comp Cams "Stump Puller" roller
Holley Ultra Street Avenger 770
Ram Air III exhaust manifolds
2.5" pipes Dynomax VT w/crossover
Edelbrock Performer RPM
TH350 2.78:1 10 bolt
Old 01-16-2020, 08:24 PM
chrisp chrisp is offline
Pioneer 500455 is a excellent part & the fit is good.
Old 01-16-2020, 09:15 PM
Schurkey Schurkey is offline
JEGS 50318
Summit SUM-G630
Pioneer 500455
What are the odds that all of those are made in the same factory, but packaged in different boxes?
"I" would be looking for an OEM cover in decent condition.
Old 01-16-2020, 10:37 PM
1968GTO421's Avatar
I've bought great quality used OEM stuff from a member on here named
Scott Thelander
That's the name he also posts under. Nice guy to deal with. You might want to check him out with a PM.
http://forums.maxperformanceinc.com/...r.php?u=151448
GTOAA--https://www.gtoaa.org/
Old 01-16-2020, 10:44 PM
wbnapier wbnapier is offline
http://www.krepower.com/Pontiac%20Timing%20Covers.htm
Kaufman
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 01-16-2020, 10:53 PM
John Milner's Avatar
John Milner John Milner is online now
I’d use a good factory timing cover and factory harmonic balancer.
Old 01-16-2020, 10:58 PM
Entropy11's Avatar
Thanks for the replies guys. Was thinking of finding an original in decent shape but I’m just skeptical of it already having some of its’ life expectancy already gone in areas that aren’t obvious. I’ll keep an eye open and follow the leads mentioned.
Interesting about about the Pioneer. All the reports I can find on that one say the fit is excellent and they find it to be of decent quality. Cheapest one of the bunch at the moment too. Thanks Chrisp for your input on that one.
Surprisingly removed the crank/balancer bolt tonight. Thought it would be much worse. But then again half the fasteners I’ve come across have been far from torque spec.
Thanks again!
Old 01-16-2020, 11:01 PM
FWIW... Paul Sandoval from Sandoval Performance recently published some Pontiac engine building books and recommended the Kaufman timing cover in them.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 01-16-2020, 11:11 PM
Entropy11's Avatar
Thanks. I did read about that one too and forgot to list it. The reviews were all good on that one too. I appreciate your input.
Old 01-17-2020, 03:32 AM
dataway's Avatar
dataway dataway is offline
The 11 bolt covers are still easy to find in good shape used ... unlike the 8 bolt pieces which command a much higher price in good shape.
Scott is also my go-to guy for OEM parts.
