Whatever you do .... don't blow debri off the top of the piston with compressed air.
I am working through these suggestions and for my engine carbon build up on the pistons here is what didn't work.
Seafoam didn't affect the carbon Gasoline no affect Choke and carb cleaner helped a little Brake kleen no help WD 40 actually helped a little Oven cleaner says do not use on aluminum I can't find CRC Gasket remover any where locally on the shelf. I have not used, but I will be trying Transmission fluid Spray Nine There is a problem trying to work on this and keep the crums out of the piston gap between piston and cylinder. Thanks Greg |
GM Top Engine Cleaner ACDelco Part# 10-3015
Motorcraft PM-2 Carb Tune UP Johnson Evinrude OMC Engine Tuner 777185
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
Thread Tools | |
Display Modes | |
