How do you ship cylinder heads?
I was curious how to ship cylinder heads. What kind of boxes or where can you get boxes.
Thanks Greg |
Its a pain but they are heavy and you don't want damage. |
I've had to get a box that was close to the right size and cut it, re-fold the flaps and tape it up. Don't forget to insulate with something. Styrofoam insulation works. But pack the head tight in the box.
Find a large cardboard box .roll up the cylinder head with several layers and wrap it tight. Cut off any excess.
2X ta man.Tom
Put the head in a grocery bag or 2.(Plastic) set it in a box with at least a 1 inch foam piece under it.Then fill around the head with a can of blow foam.Close the box lid. Get a box that leaves an few inches around the head to give the foam room to expand.You can wrap an extra layer of cardboard around the box to toughen the whole thing up.Use a buch of tape.
I had to ship some Ram Air 2 heads I had and bought some plastic tool boxes they would fit in. Wrapped the heads in shrink wrap and used spray foam to insulate them. Wrapped tool boxes in gorilla tape. Very secure. Cost about $50 in material
All good advice. I did what ta man said. At the ends I cut a wood block to fit the opening and drilled a hole in it for a finger grip then stapled all around.
69 Z 302 M21 3.73 http://www.byjanmarie.com/camaro/Z28.html 69 FB 400 http://www.byjanmarie.com/firebird/69.html 69 Camaro 327 4sp. 4.10 http://www.byjanmarie.com/camaro/69camaro.html ( SOLD) 2002 Camaro LE/SLP-(sold) 1967 Nova SS-- 327, M20, 3.73, FRT Disc |
I used the advice of Dave Bisschop. Wrapped properly they are the parcels that will wreak damage on the other parcels and stay secure in their own wrapping in the event of inproper handling or accident.
I made nice plywood boxes and shipped my iron heads to SD Performance. They came back rolled in several layers of cardboad. No damage whatsoever.
I bought a set of new aluminum heads in the original boxes and then wrapped in an other layer of cardboard sent from Fla, to Indiana.
Sent buy Scott S. arrived in prefect condition. |
For a start you can visit / call local machine shops that build motors as many times they have boxes sitting around from customers new heads that they will give away instead of filling up there cardboard dumpster.
Sell them at a swap. Lol
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes F ire B irds 🇮🇱 |
I made two crates out of old pallet wood, one head per crate. A PITA, but worked great and no damage. Customer was happy.
Jeff |
Cardboard layers and filament tape.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
i work at a meat company so the smaller meat boxes work great with some foam padding. there made to care up to 100lbs of meat. so there very tough. also use these for the cast iron intakes too...best price too..free
1970 firebird, 468, e heads, |
you have to get a special kind (anaerobic) and it's quite a bit more expensive, otherwise the foam dries unevenly and leaves pockets of liquid. That was a mess.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
Jeff |
